[petsc-users] difference between solns for np=1 and np>1.
Jed Brown jed at 59A2.org
Thu Mar 18 11:17:29 CDT 2010
On Thu, 18 Mar 2010 11:53:27 -0400, "(Rebecca) Xuefei YUAN" <xy2102 at columbia.edu> wrote:
> Dear all,
> I have a piece of code working right for np=1, but when I use np>1(for
> example, np=2), the solution is different from the one with np=1.
> I checked the residual function(f_np1_itsi vs f_np2_itsi) and Jacobian
> matrix(J_np1_itsi,J_np2_itsi), it turns out that for different initial
> guesses,
> f_np1_its0 = f_np2_its0;
> J_np1_its0 = J_np2_its0;
> although two Jacobians are the same, they have different nonzero structures.
The format is different.
> After 1 nonlinear iterations, the solution is not the same.
> I do not understand that if I have F(u^{m}) and J(u^{m}) the same, how
> could I get different \delta u^{m} in np=1 and np=2 situations?
How much different?  Is it much different with -pc_type jacobi or
-pc_type none?
http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#differentiterations
Jed
