[petsc-users] ublas sparse matrix bindings?
Umut Tabak u.tabak at tudelft.nl
Tue Jun 29 10:11:20 CDT 2010
Luke Bloy wrote:
> Umut,
> Thanks for the offer I have the basics working with
> MatCreateSeqAIJWithArrays in case you need it you can use something
> like this.
>   using boost::numeric::ublas;
>   typedef  unbounded_array<PetscInt> IndexArrayType;
>   typedef  unbounded_array<PetscScalar> ValueArrayType;
>   typedef
> compressed_matrix<PetscScalar,row_major,0,IndexArrayType,ValueArrayType>
> MatrixType;
>   MatrixType  L(10,10);
>   //Fill L
>   ierr = MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, 10, 10,
> L.index1_data().begin()
> ,L.index2_data().begin(),L.value_data().begin(),&A);
> this works so long as you use petscInt and petscScalar as the template
> parameters of MatrixType.
This might be a bit off the topic, however, I had great difficulties
when assigning some ranges to petsc matrices through the ublas
interface, I used ublas for interfacing to petsc binary matrices, and on
the level of interfacing I can tell that the combination of ublas,
petsc, and PetscExt for block operations seems to be pretty fast...
Thanks to Dave May for PetscExt ;)
