[petsc-users] help about my first petsc program
XUAN YU xxy113 at psu.edu
Mon Jun 21 16:30:10 CDT 2010
I want to learn petsc by solving a small time-dependent problem:
   The problem is from chemical kinetics, and consists of the following three
rate equations:
   dy1/dt = -.04*y1 + 1.e4*y2*y3
   dy2/dt = .04*y1 - 1.e4*y2*y3 - 3.e7*(y2)^2
   dy3/dt = 3.e7*(y2)^2
  on the interval from t = 0.0 to t = 4.e10, with initial
  conditions: y1 = 1.0, y2 = y3 = 0.
I passed the compiling, and generated an executable file. But I got a lot of -
Error Message - when I run the file. I appreciate your help and suggestions!
Many thanks!
My program is :
#include "petscts.h"
/*The problem is from
 * chemical kinetics, and consists of the following three rate
 * equations:
 *    dy1/dt = -.04*y1 + 1.e4*y2*y3
 *    dy2/dt = .04*y1 - 1.e4*y2*y3 - 3.e7*(y2)^2
 *    dy3/dt = 3.e7*(y2)^2
 * on the interval from t = 0.0 to t = 4.e10, with initial
 * conditions: y1 = 1.0, y2 = y3 = 0.
typedef struct {
    PetscInt m;
}AppCtx;
extern PetscErrorCode
FormJacobian(TS,PetscReal,Vec,Mat*,Mat*,MatStructure*,void*),
     FormFunction(TS,PetscReal,Vec,Vec,void*);
int main(int argc,char **argv)
    TS ts;
    Vec u,r;
    PetscScalar    *u_localptr;
    Mat J;
    AppCtx user;
    PetscInt its,m;
    PetscReal dt,ftime;
    PetscErrorCode ierr;
    PetscInitialize(&argc,&argv,PETSC_NULL,PETSC_NULL);
    m=3;
    dt=0.1;
  ierr = PetscOptionsGetInt(PETSC_NULL,"-m",&m,PETSC_NULL);CHKERRQ(ierr);
  user.m=m;
  u_localptr[0]=1.0;
  u_localptr[1]=0.0;
  u_localptr[2]=0.0;
  ierr = VecRestoreArray(u,&u_localptr);CHKERRQ(ierr);
  ierr = VecCreateSeq(PETSC_COMM_SELF,m,&u);CHKERRQ(ierr);
  ierr = TSCreate(PETSC_COMM_SELF,&ts);CHKERRQ(ierr);
  ierr = TSSetProblemType(ts,TS_NONLINEAR);CHKERRQ(ierr);
  ierr = TSSetSolution(ts,u);CHKERRQ(ierr);
  ierr = TSSetRHSFunction(ts,FormFunction,&user);CHKERRQ(ierr);
  ierr = TSSetRHSJacobian(ts,J,J,FormJacobian,&user);CHKERRQ(ierr);
  ierr = TSSetType(ts,TSPSEUDO);CHKERRQ(ierr);
  ierr = TSSetInitialTimeStep(ts,0.0,dt);CHKERRQ(ierr);
  ierr = TSPseudoSetTimeStep(ts,TSPseudoDefaultTimeStep,0);CHKERRQ(ierr);
  ierr = TSSetFromOptions(ts);CHKERRQ(ierr);
  ierr = TSSetUp(ts);CHKERRQ(ierr);
  ierr = TSStep(ts,&its,&ftime);CHKERRQ(ierr);
  printf("Number of pseudo timesteps = %d final time %4.2e\n",(int)its,ftime);
  ierr = VecDestroy(u);CHKERRQ(ierr);
  ierr = VecDestroy(r);CHKERRQ(ierr);
  ierr = MatDestroy(J);CHKERRQ(ierr);
  ierr = TSDestroy(ts);CHKERRQ(ierr);
  ierr = PetscFinalize();CHKERRQ(ierr);
  return 0;
PetscErrorCode FormFunction(TS ts,PetscReal t,Vec X,Vec F,void *ptr)
    PetscScalar *x,*f;
    PetscInt n;
    n=3;
     ierr = VecGetArray(X,&x);CHKERRQ(ierr);
  ierr = VecGetArray(F,&f);CHKERRQ(ierr);
    f[0]=-0.04*x[0]+1.0e4*x[1]*x[2];
    f[1]=0.04-1.0e4*x[1]*x[2]-3*1.0e7*x[1]*x[1];
    f[2]=3*1.0e7*x[1]*x[1];
  ierr = VecRestoreArray(X,&x);CHKERRQ(ierr);
  ierr = VecRestoreArray(F,&f);CHKERRQ(ierr);
  return 0;
PetscErrorCode FormJacobian(TS ts,PetscReal t,Vec X,Mat *J,Mat *B,MatStructure
*flag,void *ptr)
        Mat jac=*B;
        PetscScalar v[3],*x;
        PetscInt row,col;
       v[0]=-0.04;
       v[1]=0.04;
       v[2]=0;
       row=1;
       col=1;
      ierr = MatSetValues(jac,1,&row,1,&col,v,INSERT_VALUES);CHKERRQ(ierr);
   v[0]=1.0e4*x[2];
       v[1]=-1.0e4*x[2]-6.0e7*x[1];
       v[2]=6.0e7*x[1];
       col=2;
       v[0]=1.0e4*x[1];
       v[1]=-1.0e4*x[1];
       v[2]=0;
       col=3;
    ierr = MatAssemblyBegin(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  ierr = MatAssemblyEnd(jac,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
  return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100621/9c42029d/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100621/9c42029d/attachment.obj>
