[petsc-users] external solvers
Hong Zhang hzhang at mcs.anl.gov
Thu Feb 25 09:12:50 CST 2010
Umut:
>>   General purpose iterative methods are likely to be useless for
>> this type of problem. How large are the problems you wish to solve?
>> If less then a few million I'd stick to direct methods like MUMPS.
> Say, 5e4 to 1e5.
Sequential mumps can handle 1e4, depends on sparse
structure of matrix factors. Parallel mumps should be able to process
1e5.
> This is also the conclusion, I got from the tests and extensive
> reading I have done in the last days. The only hope was to be able
> to espace from the factorizations by using iterative methods.
Factorization is expensive.  But when your matrix is very ill-
conditioned,
iterative methods simply do not converge, or "useless for this type of
problem" as Barry mentioned.
> Simple MATLAB type tests were giving pretty promising results for a
> method that I was trying to develop(with the backslash, expensive
> however).
"\" in Matlab means director solver. It is expensive, but works.
> And it was an idea whether there can be improvement with iterative
> methods and preconditioning or not(being aware of the facts about
> the conditioning issues), Thanks again.
Again, for very ill-conditioned problems, only expensive direct
solvers work.
Hong
