[petsc-users] parallel ILU
Tue Feb 16 15:06:03 CST 2010
    I would stick to the BAIJ, since that will give you better
performance in the non-hypre part of the code, while the hypre part
has the same performance because it does not "know" about BAIJ. The
conversion cost is in my experience very small relative to the
computation times.
    Barry
On Feb 16, 2010, at 3:02 PM, Craig Tanis wrote:
> On Feb 16, 2010, at 2:51
>> As the matrix is passed to hypre it is passed as a AIJ matrix
>> without a block size. This is because hypre has no concept of a
>> BAIJ matrix. So yes, your PETSc part of the code is using a BAIJ
>> matrix but hypre is doing a scalar ILU without a block size.
> Thanks for the clarification.Is there much overhead in this
> conversion?  Would I be better off working with a AIJ matrix in the
> "driver code"?
> -craig
