[petsc-users] MatSetSizes for MATMPIBAIJ
Fri Feb 5 17:37:57 CST 2010
On Feb 5, 2010, at 5:28 PM, NovA wrote:
> Thanks for the quick response!
> 2010/2/6 Matthew Knepley <knepley at gmail.com>:
>> 1) It will distribute block rows, so you will get 8 and 4 as you want
> How can it distribute in such a way, if it doesn't know block size
> yet?
> Let's continue the example:
>   MatCreate(comm, &A);
>   MatSetSizes(A, PETSC_DECIDE,12, 12,12);
                             This is wrong! Look at the manual page
for MatCreateMPIBAIJ() for information on the meaning of this.
>   MatSetType(A, MATMPIBAIJ);
>   MatGetOwnershipRange(A, &rowS, &rowE);
>  Then loop local rows from rowS/4 to rowE/4 to preallocate storage
> using MatMPIBAIJSetPreallocation(A,4,...)
    You cannot do it this way. You cannot call MatGetOwnershipRange()
before setting the preallocation.
    You can either,
1) figure out yourself the local sizes you want to use, then just call
MatCreateMPIBAIJ() with all the information (or call MatCreate(),
MatSetType(), MatSetSizes(), MatMPIBAIJSetPreallocation())  or
2) Use PetscMap (see manual page for PetscMapInitialize) to see how
PETSc would decompose the rows and then use that information to do 1).
    Barry
In petsc-dev PetscMap has been changed to PetscLayout, see
PetscLayoutCreate().
> What will be the rowS and rowE here? I think they can be not divisible
> by 4 (block size)...
>> 2) Warning: This is an incredibly small problem. Using 2 processors
>>     might not show any speedup at all.
> Sure! It's just an example. I suppose it'll be much slower on two
> processors actually.
> Regards!
>  Andrey
>>   Matt
>> On Fri, Feb 5, 2010 at 5:03 PM, NovA <av.nova at gmail.com> wrote:
>>> Hi everybody!
>>> I'm looking for the best way to distribute MPIBAIJ matrix among
>>> several processors.
>>> For example, I have square matrix 3x3 of blocks 4x4 each (i.e. 12x12
>>> values) and need to distribute it among 2 processors. The generic
>>> way
>>> of creating such a matrix would be:
>>>  Mat A;
>>>  MatSetSizes(A, loc_rows,12, 12,12);
>>> What is the optimal value for loc_rows here?
>>> Can I use PETSC_DECIDE for it? I suppose this will lead to
>>> division by
>>> 6 rows per processor, which is not consistent with block size. How
>>> MatMPIBAIJSetPreallocation(A,4,...) will deal with it?
>>> Most likely, I have to manually set loc_rows to 8 and 4 according to
>>> the processor rank. But probably I miss some more clean way, when
>>> PETSc really decides. :)
>>> Thanks in advance for any comments.
>>> Regards!
>>>  Andrey
>> experiments
>> is infinitely more interesting than any results to which their
>> experiments
>> lead.
>> -- Norbert Wiener
