[petsc-users] MatSetSizes for MATMPIBAIJ
NovA av.nova at gmail.com
Fri Feb 5 17:28:05 CST 2010
Thanks for the quick response!
2010/2/6 Matthew Knepley <knepley at gmail.com>:
> 1) It will distribute block rows, so you will get 8 and 4 as you want
How can it distribute in such a way, if it doesn't know block size yet?
Let's continue the example:
   MatCreate(comm, &A);
   MatSetSizes(A, PETSC_DECIDE,12, 12,12);
   MatSetType(A, MATMPIBAIJ);
   MatGetOwnershipRange(A, &rowS, &rowE);
  Then loop local rows from rowS/4 to rowE/4 to preallocate storage
using MatMPIBAIJSetPreallocation(A,4,...)
What will be the rowS and rowE here? I think they can be not divisible
by 4 (block size)...
> 2) Warning: This is an incredibly small problem. Using 2 processors
>     might not show any speedup at all.
Sure! It's just an example. I suppose it'll be much slower on two
processors actually.
Regards!
  Andrey
>   Matt
> On Fri, Feb 5, 2010 at 5:03 PM, NovA <av.nova at gmail.com> wrote:
>> Hi everybody!
>> I'm looking for the best way to distribute MPIBAIJ matrix among
>> several processors.
>> For example, I have square matrix 3x3 of blocks 4x4 each (i.e. 12x12
>> values) and need to distribute it among 2 processors. The generic way
>> of creating such a matrix would be:
>>  Mat A;
>>  MatSetSizes(A, loc_rows,12, 12,12);
>> What is the optimal value for loc_rows here?
>> Can I use PETSC_DECIDE for it? I suppose this will lead to division by
>> 6 rows per processor, which is not consistent with block size. How
>> MatMPIBAIJSetPreallocation(A,4,...) will deal with it?
>> Most likely, I have to manually set loc_rows to 8 and 4 according to
>> the processor rank. But probably I miss some more clean way, when
>> PETSc really decides. :)
>> Thanks in advance for any comments.
>> Regards!
>>  Andrey
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
