[petsc-users] error check in C++ constructor
Umut Tabak u.tabak at tudelft.nl
Tue Feb 2 17:00:56 CST 2010
Dear all,
I was looking at some code C++ constructor code where some PETSc Vec's
are created in the constructor, the problem/question is that constructor
does not have a return type and CHKERRQ is a replacement for a macro
code which returns a value, that is the error code.
I guess, the safest bet to check for errors in a constructor is to
compare the return value from PETSc functions with 0 and issue an error
message from the constructor, is this reasoning right?
Best regards,
Umut
