[petsc-users] Compile and link correctly using conf/petscvariables and conf/variables
Filippo Spiga filippo.spiga at disco.unimib.it
Thu Aug 5 10:39:29 CDT 2010
  Dear users,
     I look at different examples but I'm not sure to have well
understood how to compile and link correctly using the contents of
"conf/petscvariables" and "conf/variables". My program uses both linear
and non linear solvers and different external packages such as
superlu_dist, hypre and umfpack. I looked at
"${PETSC_ROOT}/${PETSC_ARCH}/conf/petscvariables" to extract the right
path to compile and link my code. Inside this file there are all these
lines:
PETSC_CONTRIB_BASIC = -lpetsc
PETSC_SNES_LIB_BASIC = -lpetsc
PETSC_KSP_LIB_BASIC = -lpetsc
PETSC_MAT_LIB_BASIC = -lpetsc
PETSC_LIB_BASIC = -lpetsc
PETSC_VEC_LIB_BASIC = -lpetsc
PETSC_DM_LIB_BASIC = -lpetsc
PETSC_TS_LIB_BASIC = -lpetsc
PETSC_SYS_LIB_BASIC = -lpetsc
PACKAGES_LIBS = ...
but there isn't a single entry that collect in the right order all of
them. Then if I look at "${PETSC_ROOT}/${PETSC_ARCH}/conf/variables" I
can find these lines:
PETSC_EXTERNAL_LIB_BASIC = ${EXTERNAL_LIB} ${PACKAGES_LIBS}
${PCC_LINKER_LIBS}
PETSC_SYS_LIB_BASIC      = -lpetscsys
PETSC_VEC_LIB_BASIC      = -lpetscvec ${PETSC_SYS_LIB_BASIC}
PETSC_MAT_LIB_BASIC      = -lpetscmat ${PETSC_VEC_LIB_BASIC}
PETSC_DM_LIB_BASIC       = -lpetscdm ${PETSC_MAT_LIB_BASIC}
PETSC_KSP_LIB_BASIC     = -lpetscksp ${PETSC_DM_LIB_BASIC}
PETSC_SNES_LIB_BASIC     = -lpetscsnes ${PETSC_KSP_LIB_BASIC}
PETSC_TS_LIB_BASIC       = -lpetscts ${PETSC_SNES_LIB_BASIC}
PETSC_LIB_BASIC          = ${PETSC_TS_LIB_BASIC}
PETSC_CONTRIB_BASIC      = -lpetsccontrib
PETSC_SYS_LIB     = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_SYS_LIB_BASIC}  ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_VEC_LIB     = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_VEC_LIB_BASIC}  ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_MAT_LIB     = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_MAT_LIB_BASIC}  ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_DM_LIB      = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_DM_LIB_BASIC}   ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_KSP_LIB     = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_KSP_LIB_BASIC}  ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_SNES_LIB    = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_SNES_LIB_BASIC} ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_TS_LIB      = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_TS_LIB_BASIC}   ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_LIB         = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_LIB_BASIC}      ${PETSC_EXTERNAL_LIB_BASIC}
PETSC_CONTRIB     = ${C_SH_LIB_PATH} -L${PETSC_LIB_DIR}
${PETSC_CONTRIB_BASIC}
that are pretty clear. However if I look inside
"${PETSC_ROOT}/${PETSC_ARCH}/lib" I don't  see all the -lpetsc*
libraries mentioned above" I only have one single "libpetsc.a"
So, what's the right env variable to use? what is the right order of
-lpetsc* statements? Can I only link "libpetsc.a"? In this last case, is
my Makefile fully compatible and maintenable with all the future version
of PETSc?
Thank you very much in advance,
Regards
Filippo SPIGA
«Nobody will drive us out of Cantor's paradise.»
      -- David Hilbert
