[petsc-users] array and vec
Fri Apr 16 21:16:54 CDT 2010
   The manual page that Jed pointed out to you has links to several
examples that use VecGetArray() from Fortran. For example
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/src/vec/vec/examples/tutorials/ex4f.F.html
In particular you don't declare u(n) you just declare u(1)
> it seems don't work.
     This is the most useless type of email. If all you tell us is "it
seems don't work", then we have NO idea of what happened, what didn't
work, so cannot provide advice. Cut and paste all error messages and
everything that that would help us see "what didn't work".
    Barry
On Apr 15, 2010, at 8:55 PM, 陈乐平(Leping Chen) wrote:
> thanks,
> but I don't understand VecGetArray(), that is to say, I don't know
> how to call VecGetArray()
> when I plan to get any local values of x,
> Maybe,
> double precision u(n)
> Vec x
> PetscOffset uu_i
> call VecGetArray(x,u,uu_i,ierr)
> is it right?
> it seems don't work. how can I call it?
> thanks,
> leping
> 发件人: Matthew Knepley
> 发送时间: 2010-04-16  22:48:18
> 收件人: chenleping; PETSc users list
> 抄送:
> 主题: Re: [petsc-users] array and vec
> 2010/4/15 陈乐平(Leping Chen) <chenleping at yahoo.cn>
> hello, petsc teams,
> when I use FormFuncion(), I need use a value of x;
> but x is defined by Vec, I don't know how to get  a value of x, for
> example, the 3rd value.
> Exactly as Jed wrote, you can use VecGetArray() to access any local
> values
> of x.
>    Matt
> thanks,
> leping
> 发件人: Jed Brown
> 发送时间: 2010-04-16  21:21:47
> 抄送:
> On Thu, 15 Apr 2010 21:17:19 +0800, "=?gb2312?B?s8LA1sa9?=" <chenleping at yahoo.cn
> > wrote:
> > petsc teams,
> > for following definitions:
> > Vec  v
> > then, how can I actualize mutual updating between u(n) and v?
> I'm not sure what you mean, if these are the same quantity then they
> shouldn't be stored in separate locations.  See VecGetArray:
>   http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Vec/VecGetArray.html
> Jed
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100416/6cc3fa1c/attachment.htm>
