[petsc-users] Error during compiling my own code
Thu Apr 15 22:38:48 CDT 2010
If you are using petsc-dev, you only need petsc.h
   Matt
On Thu, Apr 15, 2010 at 10:27 PM, Wee-Beng Tay <zonexo at gmail.com> wrote:
> Hi,
> I have successfully built the PETSc libraries no my linux system.
> make ex1f also works.
> However, when compiling my own code, I got the error:
> [atlas5-c01]$ /app1/mvapich2/current/bin/mpif90 -c  -O3
> -I/home/svu/g0306332/codes/petsc-3.1-p0/atlas5-mpi-nodebug/include
> -I/home/svu/g0306332/codes/petsc-3.1-p0/include
> -I/home/svu/g0306332/lib/hypre-2.6.0b_atlas5/include
> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include
> -I/app1/mvapich2/1.4/include -I/app1/mvapich2/current/include    -o global.o
> global.F -132
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(10):
> error #6418: This name has already been assigned a data type.   [NORM_1]
>       integer(kind=selected_int_kind(5)) NORM_1
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(11):
> error #6418: This name has already been assigned a data type.   [NORM_2]
>       integer(kind=selected_int_kind(5)) NORM_2
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(12):
> [NORM_FROBENIUS]
>       integer(kind=selected_int_kind(5)) NORM_FROBENIUS
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(13):
> [NORM_INFINITY]
>       integer(kind=selected_int_kind(5)) NORM_INFINITY
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(14):
> error #6418: This name has already been assigned a data type.   [NORM_MAX]
>       integer(kind=selected_int_kind(5)) NORM_MAX
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(15):
> [NORM_1_AND_2]
>       integer(kind=selected_int_kind(5)) NORM_1_AND_2
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(22):
> [NOT_SET_VALUES]
>       integer(kind=selected_int_kind(5)) NOT_SET_VALUES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(23):
> [INSERT_VALUES]
>       integer(kind=selected_int_kind(5)) INSERT_VALUES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(24):
> error #6418: This name has already been assigned a data type.   [ADD_VALUES]
>       integer(kind=selected_int_kind(5)) ADD_VALUES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(25):
> error #6418: This name has already been assigned a data type.   [MAX_VALUES]
>       integer(kind=selected_int_kind(5)) MAX_VALUES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(32):
> [SCATTER_FORWARD]
>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(33):
> [SCATTER_REVERSE]
>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(34):
> [SCATTER_FORWARD_LOCAL]
>       integer(kind=selected_int_kind(5)) SCATTER_FORWARD_LOCAL
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(35):
> [SCATTER_REVERSE_LOCAL]
>       integer(kind=selected_int_kind(5)) SCATTER_REVERSE_LOCAL
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(36):
> [SCATTER_LOCAL]
>       integer(kind=selected_int_kind(5)) SCATTER_LOCAL
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(44):
> [VEC_IGNORE_OFF_PROC_ENTRIES]
>       integer(kind=selected_int_kind(5)) VEC_IGNORE_OFF_PROC_ENTRIES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(45):
> [VEC_IGNORE_NEGATIVE_INDICES]
>       integer(kind=selected_int_kind(5)) VEC_IGNORE_NEGATIVE_INDICES
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(53):
> error #6418: This name has already been assigned a data type.   [VECOP_VIEW]
>       integer(kind=selected_int_kind(5)) VECOP_VIEW
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscvec.h(54):
> [VECOP_LOADINTOVECTOR]
>       integer(kind=selected_int_kind(5)) VECOP_LOADINTOVECTOR
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(10):
> [MAT_FLUSH_ASSEMBLY]
>       integer(kind=selected_int_kind(5)) MAT_FLUSH_ASSEMBLY
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(11):
> [MAT_FINAL_ASSEMBLY]
>       integer(kind=selected_int_kind(5)) MAT_FINAL_ASSEMBLY
> /home/svu/g0306332/codes/petsc-3.1-p0/include/finclude/petscmat.h(17):
> error #6418: This name has already been assigned a data type.   [MAT_FACTO
> I don't remember having this error in prev version of PETSc. May I know
> what went wrong?
> The 1st few lines of my code are:
>     module global_data
>     implicit none
>     save
> #include "finclude/petsc.h"
> #include "finclude/petscvec.h"
> #include "finclude/petscmat.h"
> #include "finclude/petscksp.h"
> #include "finclude/petscpc.h"
> #include "finclude/petscsys.h"
>     integer ::
> size_x,size_y,Total_time_step,new_start,interval,gridgen,safe_int,OS,airfoil_no
>     integer ::
> steady,quasi_steady,Total_k,time,mom_solver,poisson_solver,start_time,motion
>     !size_x must be in multiples of 37/32/36/40/55/41, !size_y must be in
> multiples of 26/16/36
>     !gridgen1 - 32x20, gridgen4 - 30x22, gridgen5 - 30x24
>     real(8) :: CFL, Re, scheme, B, AA, BB,AB,
> ld,air_centy,Pi,hy0,k0,freq,phase_ang,theta0,loc_rot
>     real(8) :: time_sta,act_time,vel_h,vel_hn,inv_Re
> Thanks alot!
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100415/5035725d/attachment.htm>
