PETSC memory usage
Matt Funk mafunk at nmsu.edu
Tue Sep 29 17:32:53 CDT 2009
i have another question regarding how petsc uses memory w.r.t caching in
MatSetValues .
My code does the standard stuff:
1) i preallocate the memory
2) i insert the values via MatSetValues
3)i assemble it.
Say, for example i declare a 100x100 matrix with 10 NZ entries per row.
After 1), will the memory used for the matrix be 100^2*10*sizeof(double)?
After 2), will the memory used be 100^2*10*sizeof(double) from the prealloc
PLUS 100^2*10*sizeof(double) form the caching of values
After 3), will the memory then be reduced back to 100^2*10*sizeof(double)?
My concern is step 2). If it is using memory for prealloc and seperately for
caching, then is there a way to flush the cached values to the preallocated
slots? I tried finding stuff in the manual pages but i am not quite sure if i
can or not.
thanks
matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090929/ca30dded/attachment.htm>
