question on MatSetValues
Thu Sep 24 13:25:55 CDT 2009
On Sep 24, 2009, at 1:22 PM, Matt Funk wrote:
> Hi,
> i had a question concerning MatSetValues with respect to which
> values are ignored.
> I believe that PETSC ignores column indices of -1?
> My question then is, are the corresponding entries in the values
> array ignored as well?
> For example:
> int sizeOfNonZeroColumnEntries = 9
> int a_numRowsToInsert = 1
> int rowNumber 0
> //col. index vector for a given row (length 9)
> a_GlobalColNumber = {1 2 -1 4 5 6 -1 8 9}
> //corresponsing values vector for given row (length 9)
> a_Values = {x1 x2 x3 x4 x5 x6 x7 x8 x9}
> Now calling MatSetValues to insert this:
> m_ierr =
> MatSetValues(m_globalMatrix,
> a_numRowsToInsert,
> rowNumber,
> sizeOfNonZeroColumnEntries,
> &a_GlobalColNumber,
> &a_Values,
> INSERT_VALUES);
> question 1:
> will petsc insert 7 column/value pairs into the matrix, or will
> insert 9
7
> question 2:
> assuming it only inserts 7, am assume it is ok that i only
> preallocated 7 memory slots for this entry?
   Yes, you only need allocate 7.
   BTW: column (and row) indices always start at 0.
   Barry
> thanks
> matt
