ell1 norm convergence test
Ryan Yan vyan2000 at gmail.com
Tue Sep 22 11:35:01 CDT 2009
Just to share the experience. It is indeed very expansive to fetch the true
residual out. I print the ell one norm by set up my own monitor, as well as
the -ksp_monitor_true_residual.
An interesting part is that in this problem, ell_1 norm and ell_2 norm
have almost the same error-reduction history, in the sense of order of
magnitude..
Yan
On Mon, Sep 21, 2009 at 3:29 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Likely it is too expensive to use the 1-norm for stopping criteria for
> fgmres unless you can reformulate fgmres to give you back the residual
> efficiently.
>   Barry
> On Sep 21, 2009, at 2:04 PM, Ryan Yan wrote:
> Hi Barry,
>> Thanks for the suggestion.
>> I am using FGMRES as the krylov solver.  Is there a direct access to the
>> residual vector for FGMRES. I guess the answer is yes, since that's the
>> Krylov method which supports right preconditioning and provides the true
>> residual 2_Norm monitor, right?
>> If so, which header should I include to fetch the residual directly from
>> KSP_FGMRES?
>> Yan
>> On Mon, Sep 21, 2009 at 2:43 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  Yan,
>>   This depends on the Krylov method being used. For example with GMRES the
>> residual vector is NOT available at each iteration (the 2-norm of the
>> residual is approximated via a recurrence relationship).
>>   You can call KSPBuildResidual() to have the true residual computed for
>> you. Note: it is expensive because it actually builds the current solution
>> and computes r = b - A*x
>>  What we intended is that if you want the residual efficiently for example
>> for the CG method, you determine what Krylov method you want to use the
>> include the appropriate private include file and access the residual
>> directly from the data structure. This would be efficient. (but like I said
>> does not work for all methods). For cg include src/ksp/ksp/impls/cg/cgctx.h
>>  Barry
>> On Sep 21, 2009, at 12:44 PM, Ryan Yan wrote:
>> Hi All,
>> The following question is only for test and comparison reason.
>> Is there a command line option to set up using 1-Norm(sum of absolute
>> value of residuals)  as convergence monitor and test.
>> Alternatively, if I can get the residual "r" out at the end of each
>> iteration, then it is going to be much simpler, since I can just call
>> VecNorm(r, NORM_1, &r_ell1) and pass the r_ell1 into the convergence monitor
>> and test. Can anyone inform me if PETSc has an interface for the resuidual
>> r?
>> Or one has to call the convergence test:
>> MyKSPConverged(ksp,n,rnorm,flag,dummy);
>> and following the steps:
>> 1. fetch the exact solution:
>> KSPBuildSolution(ksp,PETSC_NULL_OBJECT,x,ierr)
>> 2. calculate the residual:
>> pass the Right Hand side and the Matrix in to calculate the 1-Norm. But
>> this step is *not* obvious, since the matrix and rhs is already distributed
>> over each processes.
>> 3. set up the convergence test based on the 1_Norm residual.
>> Thank you very much,
>> Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090922/52866487/attachment.htm>
