sparsity pattern setup
Fredrik Bengzon fredrik.bengzon at math.umu.se
Tue Sep 22 07:51:59 CDT 2009
This is the problem with the allocation algorithm in 3d I was talking
about. I guess i should have read the whole thread before asking stuff :)
https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2008-May/003022.html
/Fredrik
Matthew Knepley wrote:
> On Mon, Sep 21, 2009 at 4:53 PM, Fredrik Bengzon
> <fredrik.bengzon at math.umu.se <mailto:fredrik.bengzon at math.umu.se>> wrote:
>     Hi,
>     Ryan, I'm aware of Barry's post
>     https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2008-May/003020.html
>     and it workes fine for triangle meshes. However, I do not see how
>     this can be used for tetrahedral meshes.
> It is the same for tetrahedra. In fact, this algorithm can be
> generalized to work
> for any topology:
> http://arxiv.org/abs/0908.4427
>    Matt
>     /Fredrik
>     Ryan Yan wrote:
>         Hi Fredrik,
>         If I understand correctly, I have the same issue as what you
>         have here.
>         I do not have the code yet(It is also depends on how your
>         store your matrix data.).  But I can forward Barry's idea to
>         you.  Hope this is helpful to you.
>         Yan,
>            Simply read through the ASCII file(s) twice. The first time
>         count the number of blocks per row, then preallocate then read
>         through the ASCII file again reading and setting the values.
>         This will be very fast.
>          Barry
>         - Hide quoted text -
>         On Sep 20, 2009, at 10:20 AM, Ryan Yan wrote:
>            Hi All,
>            I have a large size application. Mesh size is 30000 nodes, with
>            dof 25 on each vertex. And it's 3d unstructured,  Tet, and Hex
>            mesh. In the following I will denote blksize=25
>            I am testing how to build up a PETSc matrix object quick
>         and fast.
>            The data I have is Block Compressed Sparse Row(BCSR) files.
>         And my
>            objective is to read BCSR files and generate PETSc Binaries
>            Firstly, I choose the MATMPIAIJ, I opened the BCSR data
>         files on
>            each processor, and set up the preallocation use
>          MatMPIAIJSetPreallocation(A,blksize,PETSC_NULL,blksize,PETSC_NULL);
>            The reason why I choose 25 as the number for d_nz and o_nz
>         is that
>            I do not have access to the ordering of the vertices. So
>         it's the
>            worst case set up, and it takes about 7 minutes on 30 MIPS
>            node(180 processors) to write the output into PETSc binaries.
>            Secondly, I choose the MatMPIBAIJ, and same procedure as above,
>            but also set up
>          MatMPIBAIJSetPreallocation(A,blksize,blksize,PETSC_NULL,blksize,PETSC_NULL),
>            here blksize = 25 and it's also the worst case; This
>         experiments
>            takes forever and could not generate the PETSc binaries.
>            I guess the reason why it takes so long in the MATMPIBAIJ
>         case is
>            that I did not set up the preallocation accurately. Alougth I
>            think the preallocation is also not accurate in the MATMPIAIJ
>            case, but it seems like the preallocation effect is not as
>         serious
>            as for the MPIBAIJ. Correct me please, if there are other
>         reasons.
>            Can I anyone please give a hint on how to set up the
>         preallocation
>            right for a unstructured mesh without knowing the mesh
>         ordering?
>            Thank you very much in advance,
>            Yan
>         On Mon, Sep 21, 2009 at 4:24 PM, Fredrik Bengzon
>         <mailto:fredrik.bengzon at math.umu.se>>> wrote:
>            Hi,
>            This is probably the wrong forum to ask, but does anyone have a
>            piece of code for computing the correct ndnz and nodnz vectors
>            needed for assembly of the stiffness (MPIAIJ) matrix on an
>            unstructured tetrahedral mesh given the node-to-element
>         adjacency?
>            Thanks,
>            Fredrik
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
