MatMatMult_MPIDense_MPIDense() works currently?
Fábio Leite fabioleite0 at gmail.com
Fri Sep 18 18:17:39 CDT 2009
Thanks Hong, I tested this examples (ex103.c and ex107.c) and worked fine !
Now I want to multiply two dense matrices using BLAS3 routines. I try to use
the MatMatMultNumeric_MPIDense_MPIDense() function implemented in
src/mat/impls/dense/mpi/mpidense.c but I see this error in console:
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC<http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal%5B0%5DPETSC>ERROR:
or try
http://valgrind.org on linux or man libgmalloc on Apple to find memory
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] MatMPIDenseCopyToPlapack line 1028
/home/hpcin/soft/petsc-3.0.0-p8/src/mat/impls/dense/mpi/mpidense.c
[0]PETSC ERROR: [0] MatMatMultNumeric_MPIDense_MPIDense line 1078
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 8, Fri Aug 21 14:02:12
CDT 2009
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: ./mult on a linux-gnu named hpcin08 by hpcin Fri Sep 18
19:14:55 2009
[0]PETSC ERROR: Libraries linked from
/home/hpcin/soft/petsc-3.0.0-p8/linux-gnu-c-debug/lib
[0]PETSC ERROR: Configure run at Fri Sep 18 16:03:03 2009
[0]PETSC ERROR: Configure options --download-f-blas-lapack=1
--download-plapack --with-mpi-dir=/usr/local/bin/mpich2-1.1.1p1
--with-scalar-type=real --with-precision=d[1]
Can I really use this function to multiply two dense matrices ? If not, how
can I multiply these matrices using BLAS3 routines ?
I am attaching my code if you want to see how I am doing.
Regards.
Fábio Leite Soares
Undergraduate Student of Computing Engineering
Centro de Informática - UFPE - BRAZIL
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090918/7ff49c2a/attachment-0001.htm>
10 10
5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090918/7ff49c2a/attachment-0001.c>
