memory reporting question
Matt Funk mafunk at nmsu.edu
Fri Sep 18 10:32:24 CDT 2009
Ok,
i am more confused now.
The following is part of my code:
  PetscLogDouble mem;
  PetscMemoryGetCurrentUsage(&mem);
  cout<<"PetscMemoryGetCurrentUsage: "<<mem<<"\n"; cout.flush();
  PetscMemoryGetMaximumUsage(&mem);
  cout<<"PetscMemoryGetMaximumUsage: "<<mem<<"\n"; cout.flush();
This is what is reported:
PetscMemoryGetCurrentUsage: 5.25525e+08
PetscMemoryGetMaximumUsage: 3.09055e+08
Now, unless i am missing something obvious, i am completely confused how it is
that the maximum usage can be less than the current usage.
What am i missing here?
thanks
matt
On Thursday 17 September 2009, you wrote:
> On Thu, Sep 17, 2009 at 6:04 PM, Matt Funk <mafunk at nmsu.edu> wrote:
> > Hi,
> > I am wondering whether the -memory_info option and the
> > PetscMemoryGetMaximumUsage<http://www.mcs.anl.gov/petsc/petsc-as/snapshot
> >s/petsc-current/docs/manualpages/Sys/PetscMemoryGetMaximumUsage.html#Petsc
> >MemoryGetMaximumUsage>() call report different things.
> > The reason i am asking is because i call the PetscMemoryGetCurrentUsage
> > fcn in my code and it shows:
> > 5.25558e+08.
> This call get_rusage(), so it gives you the entire process size.
> > At the end of the run the -memory_info option reports:
> > max process malloc()'ed: 4.00524e+08
> This is a sampling of rusage every time an object is destroyed.
> > max petsc malloc()'ed: 1.15254e+08.
> This is all the memory malloced using PetscMalloc() summed.
>   Matt
> > So i am a little confused by those numbers unless the fcn call is the
> > more complete picture (as said on the manual page)
> > I guess then my question is whether the -memory_info corresponds to the
> > PetscMalloc* fcns?
> > thanks
> > matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090918/8e0902c2/attachment.htm>
