DMMG with different
Wed Sep 16 15:53:30 CDT 2009
On Sep 16, 2009, at 3:55 PM, Dave May wrote:
> Hi,
>   I'm trying to use DMMG to solve linear Stokes flow discretised
> with finite elements.
> Does anyone know how to specify different matrices for the matrix
> associated with the linear system and the matrix used to construct
> the preconditioner? Ie, like choosing a different Amat and Bmat with
> KSPSetOperators().
    There is not a current user friendly way to specify this. After
you have called DMMGSetKSP() or DMMGSetSNES() you can call
MatDestroy( dmmg[level]->B) or MatDestroy( dmmg[level]->J ) for any
levels you want to change; create new matrices and put them into those
locations. Different ones for B and J if you like.
> In looking at DMMGSetKSP(), I don't see how this is possible. DMMG
> seems to generate the operator B via DMGetMatrix(), and then sets J
> equal to B. A dirty hack around the problem seemed to be to used
> PCDMMG, but I think I should be able to define different A and B
> mat's with DMMG directly.
> I also noted that PCDMMG does not appear to be a registered PC
> implementation in petsc 3.
    That is all dead code. It was an experiment that failed.
     Barry
> Thanks in advance,
>   Dave
