Questions about Blas
Wed Sep 16 09:54:49 CDT 2009
    Since you are using a fill factor of 2, I assume that you are
multiplying sparse matrices? In this case the BLAS are not used since
they are only for dense matrix computations.
    If you use Emacs take a look at the Emacs Users section in the
users manual. It will tell you a simple way to find all the
MatMatMult_*** functions. Essentially in Emacs just use
esc . MatMatMult_ then esc 0 esc . to find the next use.
    Barry
On Sep 16, 2009, at 10:38 AM, Rodrigo Araujo wrote:
> Hi All,
> I am multiplying matrices using this line of code:
> ierr = MatMatMult(A, B, MAT_INITIAL_MATRIX, ((PetscReal) 2.0),
> &C);CHKERRQ(ierr);
> But I need to see the source code of the file which has this
> function, because I´d want to see how the functions from BLAS is
> being used. Is that possible? If yes, could somebody tell me how.
> Thaks very much,
> Regards.
> Rodrigo W. Pimentel Araujo
> Engenharia da Computação
> UFPE
