a question about tolerance
Ryan Yan vyan2000 at gmail.com
Tue Sep 15 22:11:19 CDT 2009
On Tue, Sep 15, 2009 at 8:29 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Sep 15, 2009 at 6:04 PM, Ryan Yan <vyan2000 at gmail.com> wrote:
>> Thanks Jed.
>> And in the term ||Ae||/||Ax||,  PETSc impilictly assume that we use zero
>> as initial guess and here the x really means exact solution, right?
> This has nothing to do with the initial guess. Ae is the residual, and x is
> the current guess. We do not have the exact solution,
> but I guess A x^* = b, so that could have been used.
Thanks Matt.
I agree that in the print out ||Ae||/||Ax||,  x here just represents the x*.
Yan
>    Matt
>> Yan
>> On Tue, Sep 15, 2009 at 6:41 PM, Jed Brown <jed at 59a2.org> wrote:
>>> Ryan Yan wrote:
>>> > But can you say a little more about what happened in the first
>>> scenario, I
>>> > did not quite fellow you. Let's say, If I set -ksp_rtol 1e-2, what does
>>> this
>>> > mean in the left PC case. More specifically, which term will be
>>> considered
>>> > as a stop creteria for the KSP solve.
>>> Look at the first column (preconditioned residual norm).  Notice that
>>> this is decreasing by 1e-2 and 1e-3 respectively in your examples.
>>> Jed
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090915/6e99f6a1/attachment.htm>
