dummy in MyKSPConverged
Tue Sep 8 07:11:37 CDT 2009
On Tue, Sep 8, 2009 at 1:55 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Matt,
> Thanks for your explanation. I guess we are using different compilers (I'm
> using the intel 10.1) which may explain why I get a SEGV and you don't. I
> didn't change anything else in src/ksp/ksp/examples/tutorials/ex2f.F. To
> help me understand, could you please tell me where exactly the dummy is
> passed in?
        call KSPSetConvergenceTest(ksp,MyKSPConverged,                  &
     &          PETSC_NULL_OBJECT,PETSC_NULL_FUNCTION,ierr)
The PETSC_NULL_OBJECT is "dummy" in the callback.
   Matt
> Chris
> Message: 1
> Date: Mon, 7 Sep 2009 07:03:01 -0500
> From: Matthew Knepley <knepley at gmail.com>
> Subject: Re: dummy in MyKSPConverged
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID:
>         <a9f269830909070503g684e2197yc43a7232aa9b88da at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> On Mon, Sep 7, 2009 at 2:01 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> wrote:
> > Matt,
> > Thanks for your answer!
> > dummy is defined as a PETSc integer inside MyKSPConverged, so why can't I
> > set it to 0? I know it's not useful because it's just a dummy and nothing
> > happens with it, but setting it shouldn't crash the code, right? Also, if
> > setting it changes the basic definition of PETSC_NULL_OBJECT shouldn't
> you
> > get a SEGV as well, or at least some kind of trouble?
> dummy is something *you passed in* earlier in the code, and you passed in
> something that should not change. I
> do not know why you are getting an SEGV (I do not get one), but I do know
> you should not change this for the
> code to function correctly.
>  Matt
> > Chris
> > Message: 5
> > Date: Fri, 4 Sep 2009 10:49:25 -0500
> > Message-ID:
> >        <a9f269830909040849t7a8dd52dwc7fa33c6a0d313f7 at mail.gmail.com>
> > On Fri, Sep 4, 2009 at 10:35 AM, Klaij, Christiaan <C.Klaij at marin.nl>
> > wrote:
> > >   Hello,
> > > With the new version 3.0.0-p8, if I assign a value to the dummy in
> > > MyKSPConverged at the end of src/ksp/ksp/examples/tutorials/ex2f.F, I
> get
> > a
> > > segmentation fault (this didn't happen with version 2.3.3-p13). Any
> idea
> > > why?
> > 1) I do not get a SEGV
> > 2) You should not be setting this at all. You pass in PETSC_NULL_OBJECT,
> > which means you are changing the definition of that
> >    basic thing in PETSc. This can produce undefined results.
> >  Matt
> > > $ tail ex2f.F
> > >       else
> > >         flag = 0
> > >       endif
> > >       ierr = 0
> > >       dummy = 0
> > >       end
> > > $ ./ex2f -my_ksp_convergence
> > > [0]PETSC ERROR:
> > > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > probably memory access out of range
> > > [0]PETSC ERROR: Try option -start_in_debugger or
> > -on_error_attach_debugger
> > > [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC<http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal%5B0%5DPETSC>
> > > ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple
> to
> > > find memory corruption errors
> > > [0]PETSC ERROR: likely location of problem given in stack below
> > > [0]PETSC ERROR: ---------------------  Stack Frames
> > > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> > > available,
> > > [0]PETSC ERROR:       INSTEAD the line number of the start of the
> > function
> > > [0]PETSC ERROR:       is given.
> > > [0]PETSC ERROR: [0] GMREScycle line 133 src/ksp/ksp/impls/gmres/gmres.c
> > > [0]PETSC ERROR: [0] KSPSolve_GMRES line 228
> > > [0]PETSC ERROR: [0] KSPSolve line 308 src/ksp/ksp/interface/itfunc.c
> > > [0]PETSC ERROR: --------------------- Error Message
> > > [0]PETSC ERROR: Signal received!
> > > [0]PETSC ERROR:
> > > [0]PETSC ERROR: Petsc Release Version 3.0.0, Patch 8, Fri Aug 21
> 14:02:12
> > > CDT 2009
> > > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > > [0]PETSC ERROR: See docs/index.html for manual pages.
> > > [0]PETSC ERROR:
> > dr. ir. Christiaan Klaij
> > CFD Researcher
> > Research & Development
> > mailto:C.Klaij at marin.nl
> > T +31 317 49 33 44
> > MARIN
> > 2, Haagsteeg, P.O. Box 28, 6700 AA Wageningen, The Netherlands
> > T +31 317 49 39 11, F +31 317 49 32 45, I http://www.marin.nl/
> http://www.marin.nl/web/News/News-items/RD-seminar-on-September-22-few-places-left.htmR&Dseminar on September 22: few places left
> > This e-mail may be confidential, privileged and/or protected by
> copyright.
> > If you are not the intended recipient, you should return it to the sender
> > immediately and delete your copy from your system.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090908/f145f2f1/attachment.htm>
