Problem with saving the binary matrix via Matview
Nguyen, Hung V ERDC-ITL-MS Hung.V.Nguyen at usace.army.mil
Fri Sep 4 15:59:20 CDT 2009
Hello,
Yes, It is a CrayXT4. I just rerun with setting the variables below. I will
let you know if it helps.
hvnguyen:jade20% setenv MPICH_PTL_SEND_CREDITS -1
hvnguyen:jade20% setenv MPICH_MAX_SHORT_MSG_SIZE 64000
hvnguyen:jade20% setenv MPICH_UNEX_BUFFER_SIZE 240M
hvnguyen:jade20% setenv MPICH_PTL_UNEX_EVENTS 60000
>The problems will be worse if you don't have the latest Cray software on the
system.
What do you mean exactly about the latest Cray software?
>Note we generally frown up saving huge matrices to disk except for debugging
testing purposes. But as Matt notes this is not a particularly huge matrix.
With any reasonable configuration it should take very little time to write
the file.
We need to dump out some matrices required large number of iterations for
testing.
As for small application case (nrows-12856,nnzeros=675744), it took a minute
to write binary matrix to a file on CrayXT4 system so I don't know why it has
a deadlock in this case.
Thank you.
-hung
-----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Barry Smith
Sent: Friday, September 04, 2009 3:24 PM
To: PETSc users list
Subject: Re: Problem with saving the binary matrix via Matview
  Is this a Cray? You may need to set the environmental variables MPI UNEX
BUFFER SIZE and/or MPICH PTL MATCH OFF and/or MPICH PTL OTHER EVENTS and/or
MPICH MSGS PER PROC and/or MPICH PTL SEND CREDITS you will likely need to
hunt through Cray documentation to find the meaning of all this stuff. The
system.
debugging testing purposes. But as Matt notes this is not a particularly huge
matrix. With any reasonable configuration it should take very little time to
write the file.
    Good luck,
    Barry
On Sep 4, 2009, at 2:25 PM, Nguyen, Hung V ERDC-ITL-MS wrote:
> Hello,
> I have a problem with saving a matrix with the binary viewer
> PetscBinaryViewerOpen() for the matrix with nrow=853564,
> nnzeros=47191472.
> The application ran with 32 pes for more than 3 hours without writing
> any into file.
> However, the same executable ran for small size of application
> (nrows-12856,nnzeros=675744) and were able to write successfully
> binary files.
> Note: using Totalview I found that it hang in the line of
> Matview(matrix->petsc, fd);
> Thank you,
> -hung
> --- code:
>      petsc_analyst_mat(matrix->petsc);
>      sprintf(file[LOAD_MATRIX],"Matrix.at%f",t_prev);
>      PetscViewerBinaryOpen(PETSC_COMM_WORLD,
> file[LOAD_MATRIX],FILE_MODE_WRITE,&fd);
>      MatView(matrix->petsc, fd);
>      PetscViewerDestroy(fd);
> ---- Matrix info using salsa/AnaMod module:
> Computed <simple:trace> as <9.362113e+03> Computed <simple:trace-abs>
> as <9.362623e+03> Computed <simple:norm1> as <2.800000e+01> Computed
> <simple:normInf> as <2.800000e+01> Computed <simple:normF> as
> <2.404511e+02> Computed <simple:diagonal-dominance> as <-3.064463e-02>
> Could not compute <simple:symmetry-snorm> Could not compute
> <simple:symmetry-anorm> Could not compute <simple:symmetry-fsnorm>
> Could not compute <simple:symmetry-fanorm> Could not compute
> <structure:n-struct-unsymm> Computed <structure:nrows> as <853564>
> Could not compute <structure:symmetry> Computed <structure:nnzeros> as
> <47191472> Computed <structure:max-nnzeros-per-row> as <112> Computed
> <structure:min-nnzeros-per-row> as <16>
