Problem with saving the binary matrix via Matview
Nguyen, Hung V ERDC-ITL-MS Hung.V.Nguyen at usace.army.mil
Fri Sep 4 14:25:02 CDT 2009
Hello,
I have a problem with saving a matrix with the binary viewer
PetscBinaryViewerOpen() for the matrix with nrow=853564, nnzeros=47191472.
The application ran with 32 pes for more than 3 hours without writing any
into file.
However, the same executable ran for small size of application
(nrows-12856,nnzeros=675744) and were able to write successfully binary
files.
Note: using Totalview I found that it hang in the line of
Matview(matrix->petsc, fd);
Thank you,
-hung
--- code:
      petsc_analyst_mat(matrix->petsc);
      sprintf(file[LOAD_MATRIX],"Matrix.at%f",t_prev);
      PetscViewerBinaryOpen(PETSC_COMM_WORLD,
file[LOAD_MATRIX],FILE_MODE_WRITE,&fd);
      MatView(matrix->petsc, fd);
      PetscViewerDestroy(fd);
---- Matrix info using salsa/AnaMod module:
Computed <simple:trace> as <9.362113e+03>
Computed <simple:trace-abs> as <9.362623e+03>
Computed <simple:norm1> as <2.800000e+01>
Computed <simple:normInf> as <2.800000e+01>
Computed <simple:normF> as <2.404511e+02>
Computed <simple:diagonal-dominance> as <-3.064463e-02>
Could not compute <simple:symmetry-snorm>
Could not compute <simple:symmetry-anorm>
Could not compute <simple:symmetry-fsnorm>
Could not compute <simple:symmetry-fanorm>
Could not compute <structure:n-struct-unsymm>
Computed <structure:nrows> as <853564>
Could not compute <structure:symmetry>
Computed <structure:nnzeros> as <47191472>
Computed <structure:max-nnzeros-per-row> as <112>
Computed <structure:min-nnzeros-per-row> as <16>
