PETSc is slowing down in C++? continued
Thu Sep 3 07:53:37 CDT 2009
On Thu, Sep 3, 2009 at 7:34 AM, xiaoyin ji <sapphire.jxy at gmail.com> wrote:
> Hi,
> Here are the print outs
> for the very beginning, average time is about 0.8sec for the ksp solver
> KSP Object:
>  type: bicg
>  maximum iterations=10000, initial guess is zero
>  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000
>  left preconditioning
> PC Object:
>  type: bjacobi
>    block Jacobi: number of blocks = 16
>    Local solve is same for all blocks, in the following KSP and PC objects:
>  KSP Object:(sub_)
>    type: preonly
>    tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
>  PC Object:(sub_)
>    type: ilu
>      ILU: 0 levels of fill
>      ILU: factor fill ratio allocated 1
>      ILU: tolerance for zero pivot 1e-12
>      ILU: using diagonal shift to prevent zero pivot
>      ILU: using diagonal shift on blocks to prevent zero pivot
>           out-of-place factorization
>           matrix ordering: natural
>      ILU: factor fill ratio needed 1
>           Factored matrix follows
>          Matrix Object:
>            type=seqaij, rows=5672, cols=5672
>            package used to perform factorization: petsc
>            total: nonzeros=39090, allocated nonzeros=39704
>              not using I-node routines
>    linear system matrix = precond matrix:
>    Matrix Object:
>  Matrix Object:
>    type=mpiaij, rows=90746, cols=90746
>    total: nonzeros=636378, allocated nonzeros=1279114
>      not using I-node (on process 0) routines
> Norm of error 48.144, Iterations 137
> After 4000 steps, solver takes 7.5sec
> KSP Object:
>  type: bicg
> PC Object:
>  type: bjacobi
>  KSP Object:(sub_)
>    type: preonly
>  PC Object:(sub_)
>    type: ilu
>          Matrix Object:
>    Matrix Object:
>  Matrix Object:
> Norm of error 48.7467, Iterations 132
> The iterations are similar, solving time is actually increasing
> exponentially, and the matrix should not be too complicated here as
> the PETSc in Fortran solved this in 1sec.
You did not send the output of -log_summary. You will probably have to
segregate the solves into different stages in order to see the difference.
I suspect
  a) You do not have something preallocated correctly
  b) You are not freeing something (run with -malloc_dump) and thus clogging
memory
  c) something apart from PETSc is taking time
By the way, will there be a way to set a PETSc vector directly into a
> preconditioner for the ksp solver?
Do not know what you mean here.
  Matt
> Thanks!
> Best,
> Xiaoyin Ji
> Department of Materials Science and Engineering
> North Carolina State University
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090903/9cc3bda5/attachment.htm>
