KSPMonitorTrueResidualNorm and SNES
Lukasz Kaczmarczyk likask at civil.gla.ac.uk
Wed Oct 28 15:32:42 CDT 2009
> I will switch off monitor after first linear solution phase using
> KSPMonitorCancel. SNESSetFromOptions should set up it once again
Unfortunately this is not working.
> On 28 Oct 2009, at 16:40, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  You are calling SNESSetFromOptions() or KSPSetFromOptions() twice.
>> If you call it once the problem won't appear.
>>  There is an extremely ugly hack that is implemented for the
>> default monitor, but not other monitors, to prevent this double
>> printing. Whoever wrote this ugly hack should have done it properly.
>>  Barry
>> On Oct 28, 2009, at 2:39 AM, Lukasz Kaczmarczyk wrote:
>>> Hi Matt
>>> I add monitor from options only.
>>> Pleas note that for default KSP monitor a norm of preconditioned
>>> residual is printed only once. Problem exists when I monitor true
>>> residuals.
>>> Regards,
>>> Lukasz
>>> On 27 Oct 2009, at 23:23, Matthew Knepley <knepley at gmail.com> wrote:
>>>> It is possible to add the monitor twice. Are you sure this did
>>>> not happen?
>>>> Thanks,
>>>>   Matt
>>>> On Tue, Oct 27, 2009 at 6:19 PM, Lukasz Kaczmarczyk <likask at civil.gla.ac.uk
>>>> > wrote:
>>>> Hello,
>>>> I have noticed minor problem, potentially bug. For nonlinear
>>>> analysis with SNES and option -ksp_monitor_true_residual I get
>>>> 0 Norm Res_strain 9.36e-12 Norm Res_stress 1.43e-05 Internal
>>>> its   1
>>>> 0 SNES Function norm 1.428489691212e-05
>>>>  0 KSP preconditioned resid norm 7.213823259362e-04 true resid
>>>> norm 1.428489691212e-05 ||Ae||/||Ax|| 1.000000000000e+00
>>>>  1 KSP preconditioned resid norm 4.903423697449e-04 true resid
>>>> norm 9.339595309685e-06 ||Ae||/||Ax|| 6.538090801174e-01
>>>> It look that function KSPMonitorTrueResidualNorm is evaluated
>>>> twice, whereas for default KSP monitor only once. I use
>>>> petsc-3.0.0-p7.
>>>> Kind regards,
>>>> Lukasz
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to
>>>> which their experiments lead.
>>>> -- Norbert Wiener
Lukasz Kaczmarczyk
Lecturer
Department of Civil Engineering,
University of Glasgow,
GLASGOW, G12 8LT
Tel: +44 141 3305348
email: likask at civil.gla.ac.uk
web: http://www.civil.gla.ac.uk/~kaczmarczyk/
web: http://code.google.com/p/yaffems/
