[petsc-users] Problems with the intel compilers
Sean Dettrick sdettrick at gmail.com
Tue Oct 27 18:22:52 CDT 2009
Intel optimization is slow, and is turned on by default.  If you turn
off intel optimization completely with -O0, then you'll probably find
compilation speeds up to be similar to gnu.
Is the increased compilation time of intel worth it?  We find intel
programs are usually faster than gnu ones.  And the intel debugger idb
is in many ways more powerful than gdb.  But on the other hand we have
a fortran based CG solver where gfortran compiled code is much faster
than the intel one.
Cheers,
Sean
On Oct 27, 2009, at 3:54 PM, Dominik Szczerba wrote:
> Thanks Ando, I know of the slight speed advantage in some cases on
> the Intel side, but the question was more why the compilation takes
> so much longer?
> Dominik
> Andreas Grassl wrote:
>> Hi Dominik,
>>> I have noticed already a longer while ago: setting up PETSc with the
>>> Intel compilers (--with-cc=icc --with-cxx=icpc) takes an order of
>>> magnitude longer than with the native GNU. The step taking most of
>>> the
>>> time is configuring mpich. I have tried to configure mpich
>>> separately
>>> and indeed, with gnu it is a breeze, with intel 10x slower. In both
>>> cases, linux both 32 and 64 bit, Ubuntu 9.04 and debian testing.
>>> Intel
>>> compilers 10.x and 11.x.
>>> I just wanted to ask opinion if anybody has similar observations
>>> and/or
>>> finds using intel worthwhile at all.
>> On itanium machines intel compilers produce much faster code
>> compared to
>> gnu-compilers. On other machines I did not notice a big speed
>> difference, but I
>> think intel compilers produce slightly faster code as well.
>> Cheers,
>> ando
