Memory leaks??
Sun Oct 25 12:51:13 CDT 2009
    This is a leak caused by the OS, there is nothing one can do about
it.
     It also doesn't matter since it only happens once at the
beginning of the run.  It will not cause memory consumption to
increase over time.
     Suggest running with -malloc_dump to see if some object is not
freed.
    Barry
On Oct 25, 2009, at 10:04 AM, Billy Araújo wrote:
> I ran my application with PETSc and verified that memory consumption
> increased over time. I am not sure what is happening.
> Running my application with valgrind I get several leaks such as:
> ==25943== 16 bytes in 1 blocks are indirectly lost in loss record 9
> of 11
> ==25943==    at 0x4024C1C: malloc (vg_replace_malloc.c:195)
> ==25943==    by 0x4380C60: tsearch (tsearch.c:281)
> ==25943==    by 0x4393D2D: __nss_lookup_function (nsswitch.c:342)
> ==25943==    by 0x4831F25: ???
> ==25943==    by 0x4832B5C: ???
> ==25943==    by 0x434CCE4: getpwuid_r@@GLIBC_2.1.2 (getXXbyYY_r.c:253)
> ==25943==    by 0x434C64E: getpwuid (getXXbyYY.c:117)
> ==25943==    by 0x85DF39E: PetscGetUserName (fuser.c:68)
> ==25943==    by 0x859E6D9: PetscErrorPrintfInitialize (errtrace.c:68)
> ==25943==    by 0x85D0F78: PetscInitialize (pinit.c:521)
> ==25943==    by 0x8050E37: main (main.c:516)
> In main.c:516, I just have:
>   PetscInitialize (&argc, &argv, (char *) 0, help);
>  which I thing is the normal way of calling PetscInitialize.
> Regards,
> Billy.
