[petsc-users] different results with 1 and more CPUs
Jed Brown jed at 59A2.org
Fri Oct 23 14:51:30 CDT 2009
Dominik Szczerba wrote:
> After several months of code stability I experience now the famous
> infamous dependence of my results on the # of CPUs (and more precisely,
> divergence with -np > 4). I upgraded Petsc version meanwhile, but I want
> to start by assuming I have a problem. Any pointers to how to set up a
> trap for this bug are highly appreciated.
It's hopeless to get bit-for-bit identical answers from any parallel
program, but the situation is much trickier with iterative solvers
because almost every preconditioner is a different algorithm when you
change the distribution.  That said, you should be able to get the
differences to converge by tightening tolerances (until you run out of
floating point precision with very ill-conditioned systems).
When you have a convergence problem in the linear solver, try a direct
solver, -pc_type lu -pc_factor_mat_solver_package mumps (or even
-pc_type redundant if you don't have a parallel direct solver).  You can
also write out a matrix in parallel (see MatView()) and compare it to
the serial matrix.  If you use SNES, I recommend running a small problem
size in parallel and using -snes_type test which compares your Jacobian
to one computed by finite differences.  If you are still having problems
after confirming that your function evaluation and matrix assembly is
correct in parallel, the preconditioner is almost certainly the culprit.
You have 3 options:
1. Use a parallel direct solver like MUMPS
2. Try to brute-force a standard preconditioner, e.g.
  -pc_type asm -pc_asm_overlap 3 -sub_pc_type lu
3. Read up on/design a problem-specific preconditioner that actually
works and implement it.
As Barry said here the other day, (3) is probably only a good choice if
you want to do research in this rather than get some problems solved.
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091023/48e84a72/attachment.pgp>
