One simple question about complex number
Jed Brown jed at 59A2.org
Thu Oct 22 15:32:32 CDT 2009
Yujie wrote:
> Thank you for you reply, Satish. STL is Standard Template Library. I
> think stl::complex should be the same with std::complex.
The STL complex type is std::complex (STL uses the namespace std::), are
you sure that you have an stl::complex?
Jed
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091022/91c0d10d/attachment.pgp>
