C++ error! MPI_Finalize() could not be located!
Dominik Szczerba dominik at itis.ethz.ch
Wed Oct 21 06:23:13 CDT 2009
I get the following error building petsc-3.0.0-p8 on 32 bit linux
(Ubuntu 9.04):
                                                  Running make on MPICH;
this may take several minutes
                                            TESTING: CxxMPICheck from
config.packages.MPI(config/BuildSystem/config/packages/MPI.py:599)
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
Tail of configure.log:
for details):
   File "./config/configure.py", line 217, in petsc_configure
     framework.configure(out = sys.stdout)
   File
"/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/framework.py",
line 902, in configure
     child.configure()
   File
"/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/package.py",
line 445, in configure
     self.executeTest(self.configureLibrary)
   File
"/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/base.py",
line 97, in executeTest
     ret = apply(test, args,kargs)
   File
"/home/domel/pack/petsc-3.0.0-p8/config/BuildSystem/config/packages/MPI.py",
line 695, in configureLibrary
     self.executeTest(self.CxxMPICheck)
   File
   File
line 613, in CxxMPICheck
     raise RuntimeError('C++ error! MPI_Finalize() could not be located!')
The configure line:
./config/configure.py --with-cc=icc --with-fc=ifort
--download-f-blas-lapack=1 --download-mpich=1 --download-hypre=1 --with-x=0
with the Intel compiler version 11.0.083 (with -long_double
and -no-multibyte-chars in icc.cfg).
The same configuration (OS, compilers, versions) but on 64 bit system
compiles fine. Any ideas? Google is silent.
with regards,
Dominik
