Building Issues on BGL
Tue Oct 13 13:24:31 CDT 2009
You have to remove the defines or rename them to something else in
petscconf.h. Just commenting or undefining doesn't work. [this is
because our build system does a grep on this file - so its doesn't
exactly follow preprocessing directives]
Regarding the original issue - I'm not sure why it doesn't work. We
have V1R3M0_460_2008-081112P on our BGP - and I don't remember seeing
this issue.
Also - note; logfiles configure.log etc. should be sent to petsc-maint
- and not the mailing list [we don't want to flood huge log files to
all folks on this list]
Satish
On Tue, 13 Oct 2009, Niall Moran wrote:
> 1) Please find attached the configure.log.
> 2) It seems just commenting out the definition of PETSC_USE_SOCKET_VIEWER did
> not work but by undefining no attempt was made to build anything in the
> directory.
> #if defined(PETSC_USE_SOCKET_VIEWER)
> #undefine PETSC_USE_SOCKET_VIEWER
> #endif
> Many thanks,
> Niall.
> On 13 Oct 2009, at 14:48, Matthew Knepley wrote:
> > 1) We always need configure.log
> > 2) If you remove PETSC_USE_SOCKET_VIEWER, nothing in that directory will be
> > built
> >  Matt
> > On Tue, Oct 13, 2009 at 8:28 AM, Niall Moran <nmoran at thphys.nuim.ie> wrote:
> > Hi,
> > I am having issues compiling the latest version of PETSc on a Bluegene/L
> > machine. I am using the IBM compilers version
> > V1R3M3_420_2007-071023.
> > The error I am getting during compile is
> > ...../petsc-3.0.0-p8/src/sys/viewer/impls/socket
> > "send.c", line 105.12: 1540-0274 (S) The name lookup for "gethostbyname" did
> > not find a declaration.
> > "send.c", line 110.37: 1540-0251 (S) The "->" operator cannot be applied to
> > the undefined class "struct hostent".
> > "send.c", line 110.48: 1540-0251 (S) The "->" operator cannot be applied to
> > "send.c", line 112.21: 1540-0251 (S) The "->" operator cannot be applied to
> > "send.c", line 115.21: 1540-0251 (S) The "->" operator cannot be applied to
> > "send.c", line 188.8: 1540-0274 (S) The name lookup for "gethostbyname" did
> > "send.c", line 191.21: 1540-0251 (S) The "->" operator cannot be applied to
> > "send.c", line 197.34: 1540-0274 (S) The name lookup for "SO_REUSEADDR" did
> > /usr/bin/ar: send.o: No such file or directory
> > The config file I am using is below. I have tried commenting out some of the
> > variables defined in the petscconf.h but to no avail. The variables I tried
> > were
> > PETSC_HAVE_SYS_SOCKET_H
> > PETSC_HAVE_GETHOSTBYNAME
> > PETSC_HAVE_SOCKET
> > I never encountered such issues with PETSc pre release 3. Any help is
> > greatly appreciated.
> > Regards,
> > Niall.
> > configure_options = [
> > '--with-cc=mpixlc',
> > '--with-cxx=mpixlcxx',
> > '--with-fc=mpixlf90 -qnosave -qfixed=72',
> > '--with-mpi-dir=/bgl/BlueLight/ppcfloor/bglsys',  # required by BLACS to get
> > mpif.h
> > '--with-clanguage=cxx',
> > '--with-is-color-value-type=short',
> > '--with-shared=0',
> > '-COPTFLAGS=-O3 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1',
> > '-CXXOPTFLAGS=-O3 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1',
> > '-FOPTFLAGS=-O3 -qbgl -qarch=440d -qtune=440 -qmaxmem=-1',
> > '-LIBS=-lc -lnss_files -lnss_dns -lresolv',
> > '--with-debugging=0',
> > '--with-scalar-type=complex',
> > # the following option gets automatically enabled on BGL/with IBM compilers.
> > # '--with-fortran-kernels=bgl'
> > '--with-batch=1',
> > '--with-memcmp-ok',
> > '--sizeof_char=1',
> > '--sizeof_void_p=4',
> > '--sizeof_short=2',
> > '--sizeof_int=4',
> > '--sizeof_long=4',
> > '--sizeof_size_t=4',
> > '--sizeof_long_long=8',
> > '--sizeof_float=4',
> > '--sizeof_double=8',
> > '--bits_per_byte=8',
> > '--sizeof_MPI_Comm=4',
> > '--sizeof_MPI_Fint=4',
> > '--have-mpi-long-double=1',
> > '--download-f-blas-lapack=1',
> > '--download-hypre=0',
> > '--download-spooles=0',
> > '--download-superlu=0',
> > '--download-parmetis=0',
> > '--download-superlu_dist=0',
> > '--download-blacs=1',
> > '--download-scalapack=1',
> > '--download-mumps=0'
> > What most experimenters take for granted before they begin their experiments
> > is infinitely more interesting than any results to which their experiments
> > lead.
> > -- Norbert Wiener
