SBAIJ issue
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Mon Oct 12 08:03:04 CDT 2009
Hello,
I'm trying to work with MUMPS-Cholesky as direct solver and CG as iterative
solver and have problems with SBAIJ-Matrices.
I have a MatSetValues-line not regarding the symmetry but force it by the
command line option -mat_ignore_lower_triangular.
The problems show up at "bigger" problems (~450000 DOF) with "more" processes (1
and 2 work fine, 4 gives a hangup) and/or trying to save the matrix. The machine
has 4 cores and 12 GB memory. NNZ per row is ~80.
Attached you find the output of the program run with -info.
Any hints where to search?
Cheers,
ando
 /"\                               Grassl Andreas
 \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
  X      against HTML email        Technikerstr. 13 Zi 709
 / \                               +43 (0)512 507 6091
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091012/cdf0afd0/attachment-0003.diff>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091012/cdf0afd0/attachment-0004.diff>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091012/cdf0afd0/attachment-0005.diff>
