a problem with error of "An error occurred in MPI_Comm_rank after MPI was finalized"
Thomas Witkowski thomas.witkowski at tu-dresden.de
Mon Oct 12 01:34:49 CDT 2009
Put the functions PetscInitialize(...) and PetscFinalize() out of the
function when using it in a loop. Both functions have to be called only
once in your program.
Thomas
Yin Feng wrote:
> I put PETSc solver in one function and use another function to call that.
> This problem only appears when I put the function with PETSc solver in
> a loop,
> it works well at first step, and reports error "An error occurred in
> at second time. The program is designed to support only one processor
> like:
> Vec            x,b;
> Mat            A;
> KSP            ksp;
> PC             pc;
> PetscInt       i,j,col[N];
> PetscScalar    value[N];
> PetscScalar    val;
> PetscInitialize(PETSC_NULL,PETSC_NULL,PETSC_NULL,PETSC_NULL);
> VecCreate(PETSC_COMM_WORLD,&x);
> VecSetSizes(x,PETSC_DECIDE,N);
> VecSetFromOptions(x);
> VecDuplicate(x,&b);
> MatCreate(PETSC_COMM_WORLD,&A);
> MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,N,N);
> MatSetFromOptions(A);
> KSPCreate(PETSC_COMM_WORLD,&ksp);
> KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);
> KSPGetPC(ksp,&pc);
>  KSPSetTolerances(ksp,tol,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);
>         KSPSetFromOptions(ksp);
>         KSPSolve(ksp,b,x);
>         VecDestroy(x);
>         VecDestroy(b);
>         MatDestroy(A);
>         KSPDestroy(ksp);
>         PetscFinalize();
> Any one has ideal about this?
> The detailed error description is:
> *** after MPI was finalized
> *** MPI_ERRORS_ARE_FATAL (goodbye)
> Abort before MPI_INIT completed successfully; not able to guarantee
> that all other processes were killed!
> Thank you so much in advance!
