Question about usage of DA object
Matt Funk mafunk at nmsu.edu
Thu Oct 8 15:21:44 CDT 2009
i was wondering if i can get some advice on how to use the DA objec tin PETSC.
Is it possible to create a DA object by inserting a set of boxes into it? Or
can the DA object only be used based on a single rectangular box?
say my domain has 2 boxes:
1) (0,0) - (64,64)
2) (64,64) - (128,128)
Can i "register" those 2 boxes with the object?
If that is possible, then is it valid if certain cells/nodes of these boxes
overlap? say they both contain cell/node (64,64)?
If that is possible, and i run in parallel, will the solution on cell/node
(64,64) be returned to both processes (the first owning box1 and the second
box2).
Right now i am building my matrix 'by hand' and i believe the mentioned
"overlap" is causing an ill-conditioned matrix (as addressed earlier in this
list), even through the values on the overlapping nodes are the same.
thanks
matt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091008/926726cf/attachment.htm>
