convergence monitoring
Andreas Grassl Andreas.Grassl at student.uibk.ac.at
Mon Oct 5 11:09:02 CDT 2009
Hello,
I want to monitor the convergence of the KSP-solver, i.e. plot the number of
iterations vs. the error/residual norm.
I discovered the options -ksp_monitor_draw_true_residual and
-ksp_monitor_true_residual.
Now the questions: What does the grafical output of
-ksp_monitor_draw_true_residual represent? I see the iteration count at the
x-axis and expected the norm of the residual at the y-axis, and some scaled
value at the y-axis. Is this the logarithm of the residual/which residual?
If I output to .ps, I get overlayed the steps and don't see anything useful at
the end. Is there a way to extract only the last picture?
Is there an easy (without hacking the PETSc sources) way to output a customized
convergence monitoring line like -ksp_monitor_true_residual at every step?
Cheers,
ando
 /"\                               Grassl Andreas
 \ /    ASCII Ribbon Campaign      Uni Innsbruck Institut f. Mathematik
  X      against HTML email        Technikerstr. 13 Zi 709
 / \                               +43 (0)512 507 6091
