PCFieldSplit and Schur
francois pacull fpacull at fluorem.com
Tue Nov 24 11:38:26 CST 2009
Yes, here is what I am getting
francois.
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or
-on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
ERROR: [1]PETSC ERROR:
[1]PETSC ERROR: or try http://valgrind.org on linux or man libgmalloc on
Apple to find memory corruption errors
Caught signal number 11 SEGV: Segmentation Violation, probably memory
access out of range
[0]PETSC ERROR: likely location of problem given in stack
below
[1]PETSC ERROR: Try option -start_in_debugger or
[1]PETSC ERROR: [0]PETSC ERROR: ---------------------  Stack Frames
or see
http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[1]PETSC
ERROR: or try http://valgrind.org on linux or man libgmalloc on Apple to
[1]PETSC ERROR: likely location of problem given in stack
below
[1]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
available,
[1]PETSC ERROR: [0]PETSC ERROR:       INSTEAD the line number of the
start of the function
[0]PETSC ERROR:       INSTEAD the line number of the start of the
function
[1]PETSC ERROR:       is
given.
      is
given.
[0]PETSC ERROR: [0] PCFieldSplitGetSubKSP_FieldSplit_Schur line 751
src/ksp/pc/impls/fieldsplit/fieldsplit.c
[1]PETSC ERROR: [1] PCFieldSplitGetSubKSP_FieldSplit_Schur line 751
[1]PETSC ERROR: [0]PETSC ERROR: [0] PCFieldSplitGetSubKSP line 951
[1] PCFieldSplitGetSubKSP line 951
[1]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal
received!
[1]PETSC ERROR: Petsc Release Version 3.0.0, Patch 7, Mon Jul  6
11:33:34 CDT 2009
Signal
received!
[1]PETSC ERROR: See docs/changes/index.html for recent
updates.
See docs/faq.html for hints about trouble
shooting.
[1]PETSC ERROR: See docs/index.html for manual
pages.
[0]PETSC ERROR: [1]PETSC ERROR: Petsc Release Version 3.0.0, Patch 7,
Mon Jul  6 11:33:34 CDT 2009
Matthew Knepley a écrit :
> Can you use the debugger to get a stack trace?
>  Matt
> On Tue, Nov 24, 2009 at 10:46 AM, francois pacull <fpacull at fluorem.com
> <mailto:fpacull at fluorem.com>> wrote:
>     Dear PETSc team,
>     I am having a little bit of trouble with the Schur option of
>     PCFieldSplit: I would like to apply some special treatments
>     respectively to the five first and the two last equations over
>     seven for each grid node of a CFD linear system...
>     In the present case, the KSP is "gmres" (or "fgmres" if the PC is
>     changing), the PC is "asm" (the subdomain IS is defined with
>     PCASMSetLocalSubdomains in order to always include all the fields
>     associated to the grid points of the overlap), the SUBKSP is
>     "preonly" and the SUBPC is "fieldsplit".
>     So far the FieldSplit options PC_COMPOSITE_ADDITIVE and
>     PC_COMPOSITE_MULTIPLICATIVE work well with fieldsplit_0 and
>     fieldsplit_1 set to KSPPREONLY and PCILU in the following way:
>     PCFieldSplitGetSubKSP(SubPC,number_of_split,&FieldSplitKSP);
>     ... [for the fields 0,1,2,3,4 (fieldsplit_0)]
>     KSPSetType(FieldSplitKSP[0],KSPPREONLY);
>     KSPGetPC(FieldSplitKSP[0],&FieldSplitPC0);
>     PCSetType(FieldSplitPC0,PCILU);
>     ... [for the fields 5 and 6 (fieldsplit_1)]
>     KSPSetType(FieldSplitKSP[1],KSPPREONLY);
>     KSPGetPC(FieldSplitKSP[1],&FieldSplitPC1);
>     PCSetType(FieldSplitPC1,PCILU);
>     They also work well when I set the FieldSplitKSP[0] and/or
>     FieldSplitKSP[1] to KSPGMRES. However, I always get a segmentation
>     violation when I try to use the FieldSplit option
>     PC_COMPOSITE_SCHUR... I guess that I am missing something: is
>     there more options to set in this Schur case?
>     So far I did not turn on the Schur complement preconditioner
>     option: PCFieldSplitSchurPrecondition(subpc,PETSC_FALSE);
>     Is there a book or article describing the methods implemented in
>     this FieldSplit option?
>     The version is petsc-3.0.0-p7...
>     Thank you for your help,
>     Regards,
>     francois pacull.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
