scaling in 4-core machine
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Wed Nov 18 09:26:48 CST 2009
Does anybody have good references in the literature analyzing the memory
access patterns for sparse solvers and how they scale?  I remember seeing
Barry's talk about multigrid memory access patterns, but I'm not sure if
I've ever seen a good paper reference.
Cheers,
Aron
On Wed, Nov 18, 2009 at 6:14 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Just want to add one more point to this.
> Most multicore machines do not provide scalable hardware. [yeah - the
> FPUs cores are scalable - but the memory subsystem is not]. So one
> should not expect scalable performance out of them. You should take
> the 'max' performance you can get out out them - and then look for
> scalability with multiple nodes.
> Satish
> On Wed, 18 Nov 2009, Jed Brown wrote:
> > jarunan at ascomp.ch wrote:
> > > Hello,
> > > I have read the topic about performance of a machine with 2 dual-core
> > > chips, and it is written that with -np 2 it should scale the best. I
> > > would like to ask about 4-core machine.
> > > I run the test on a quad core machine with mpiexec -n 1, 2 and 4 to see
> > > the parallel scaling. The cpu times of the test are:
> > > Solver/Precond/Sub_Precond
> > > gmres/bjacobi/ilu
> > > -n 1, 1917.5730 sec,
> > > -n 2, 1699.9490 sec, efficiency = 56.40%
> > > -n 4, 1661.6810 sec, efficiency = 28.86%
> > > bicgstab/asm/ilu
> > > -n 1, 1800.8380 sec,
> > > -n 2, 1415.0170 sec, efficiency = 63.63%
> > > -n 4, 1119.3480 sec, efficiency = 40.22%
> > These numbers are worthless without at least knowing iteration counts.
> > > Why is the scaling so low, especially with option -n 4?
> > > Would it be expected to be better running with real 4 CPU's instead of
> a
> > > quad core ship?
> > 4 sockets using a single core each (4x1) will generally do better than
> > 2x2 or 1x4, but 4x4 costs about the same as 4x1 these days.  This is a
> > very common question, the answer is that a single floating point unit is
> > about 10 times faster than memory for the sort of operations that we do
> > when solving PDE.  You don't get another memory bus every time you add a
> > core so the ratio becomes worse.  More cores are not a complete loss
> > because at least you get an extra L1 cache for each core, but sparse
> > matrix and vector kernels are atrocious at reusing cache (there's not
> > much to reuse because most values are only needed to perform one
> > operation).
> > Getting better multicore performance requires changing the algorithms to
> > better reuse L1 cache.  This means moving away from assembled matrices
> > where possible and of course finding good preconditioners.  High-order
> > and fast multipole methods are good for this.  But it's very much an
> > open problem and unless you want to do research in the field, you have
> > to live with poor multicore performance.
> > When buying hardware, remember that you are buying memory bandwidth (and
> > a low-latency network) instead of floating point units.
> > Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091118/1fdcbea5/attachment.htm>
