malloc(): memory corruption:
Sat Nov 14 21:22:28 CST 2009
   If you run without hypre preconditioner but use instead, say
bjacobi under valgrind do you get any valgrind errors?
    The problem you are having could be do to (1) some memory
corruption in your code that is messing up hypre or (2) some bug in
hypre that we don't see with our simple test codes.
    Barry
On Nov 14, 2009, at 4:41 PM, Dominik Szczerba wrote:
> No I am using Hypre built automatically along with petsc...
> I will try ex10, thanks...
> Matthew Knepley wrote:
>> This is already bad. You had an Invalid Read and Invalid Write in
>> your Hypre. Did you build it
>> yourself? If so, let us build it. If not, please try your matrix on
>> KSP ex10 and see if you get a
>> crash on 2 procs.
>>  Thanks,
>>    Matt
>> On Sat, Nov 14, 2009 at 3:51 PM, Dominik Szczerba <dominik at itis.ethz.ch
>>  <mailto:dominik at itis.ethz.ch>> wrote:
>>    run onlu in single, he says things like below - but does not
>> crash.
>>    Also, the program run with -np 1 does not crash. No clear idea
>>    though about valgrind's output, please advise if this tells you
>>    anything...
>>    Call from NS3T10::createSolverContexts() referenced therein is:
>>    ierr = KSPCreate(petsc_comm,&kspSchurVelocity);CHKERRQ(ierr);
>>    ==2605== Conditional jump or move depends on uninitialised
>> value(s)
>>    ==2605==    at 0x8AE720F: hypre_BoomerAMGSetPlotFileName
>>    (par_amg.c:2115)
>>    ==2605==    by 0x8AE7ED9: hypre_BoomerAMGCreate (par_amg.c:276)
>>    ==2605==    by 0x8AE4A71: HYPRE_BoomerAMGCreate
>> (HYPRE_parcsr_amg.c:31)
>>    ==2605==    by 0x8562019: PCHYPRESetType_HYPRE (hypre.c:850)
>>    ==2605==    by 0x8563068: PCHYPRESetType (hypre.c:964)
>>    ==2605==    by 0x80E67BB: NS3T10::createSolverContexts()
>>    (NS3T10mpi.cxx:1980)
>>    ==2605==    by 0x80EA63B: NS3T10::solve() (NS3T10mpi.cxx:2306)
>>    ==2605==    by 0x8104860: main (ns3t10mpi_main.cxx:1516)
>>    ==2605==
>> value(s)
>>    ==2605==    at 0x8AE7244: hypre_BoomerAMGSetPlotFileName
>>    (par_amg.c:2120)
>>    ==2605==
>> value(s)
>>    ==2605==    at 0x4025C16: strcpy (mc_replace_strmem.c:303)
>>    ==2605==    by 0x8AE727A: hypre_BoomerAMGSetPlotFileName
>>    (par_amg.c:2123)
>>    ==2605==
>> value(s)
>>    ==2605==    at 0x4025C35: strcpy (mc_replace_strmem.c:303)
>>    (par_amg.c:2123)
>>    ==2605==
>>    Solver contexts created in 2.520000 s
>>    Starting KSPSolve (0/1)
>>      0 KSP Residual norm 8.368803253774e-06
>>    ==2605== Invalid read of size 8
>>    ==2605==    at 0x8B23B5A: hypre_BoomerAMGCreateS (par_strength.c:
>> 223)
>>    ==2605==    by 0x8AE966F: hypre_BoomerAMGSetup (par_amg_setup.c:
>> 630)
>>    ==2605==    by 0x8AE4A4D: HYPRE_BoomerAMGSetup
>> (HYPRE_parcsr_amg.c:58)
>>    ==2605==    by 0x855A5D9: PCSetUp_HYPRE (hypre.c:134)
>>    ==2605==    by 0x86256A9: PCSetUp (precon.c:794)
>>    ==2605==    by 0x85A6E62: KSPSetUp (itfunc.c:237)
>>    ==2605==    by 0x85A7EAB: KSPSolve (itfunc.c:353)
>>    ==2605==    by 0x80F5B16: applyPrecSchur(void*, _p_Vec*, _p_Vec*)
>>    (NS3T10mpi.cxx:3741)
>>    ==2605==    by 0x851C47E: PCApply_Shell (shellpc.c:129)
>>    ==2605==    by 0x862074E: PCApply (precon.c:357)
>>    ==2605==    by 0x863AC4C: KSPInitialResidual (itres.c:64)
>>    ==2605==    by 0x85EB09A: KSPSolve_GMRES (gmres.c:241)
>>    ==2605==  Address 0xafae5d0 is 0 bytes after a block of size
>> 93,488
>>    alloc'd
>>    ==2605==    at 0x4023F5B: calloc (vg_replace_malloc.c:418)
>>    ==2605==    by 0x8B4E9C7: hypre_CAlloc (hypre_memory.c:121)
>>    ==2605==    by 0x8B4CA67: hypre_CSRMatrixInitialize
>> (csr_matrix.c:91)
>>    ==2605==    by 0x8B32EC8: hypre_ParCSRMatrixInitialize
>>    (par_csr_matrix.c:200)
>>    ==2605==    by 0x8AE0C44: hypre_IJMatrixInitializeParCSR
>>    (IJMatrix_parcsr.c:272)
>>    ==2605==    by 0x8ADBE09: HYPRE_IJMatrixInitialize
>>    (HYPRE_IJMatrix.c:302)
>>    ==2605==    by 0x891AD3A: MatHYPRE_IJMatrixFastCopy_SeqAIJ
>> (mhyp.c:174)
>>    ==2605==    by 0x891A2E1: MatHYPRE_IJMatrixCopy (mhyp.c:131)
>>    ==2605==    by 0x855A445: PCSetUp_HYPRE (hypre.c:130)
>>    ==2605==
>>    ==2605== Invalid write of size 4
>>    ==2605==    at 0x8B23E0C: hypre_BoomerAMGCreateS (par_strength.c:
>> 301)
>> 630)
>>    ==2605==  Address 0xb12a050 is 0 bytes after a block of size
>> 46,744
>>    alloc'd
>>    ==2605==    by 0x8B23980: hypre_BoomerAMGCreateS (par_strength.c:
>> 163)
>> 630)
>>    ==2605==
>>    ==2605==    at 0x8B1ACE8: hypre_BoomerAMGRelax (par_relax.c:182)
>>    ==2605==    by 0x8B1DFBF: hypre_BoomerAMGRelaxIF
>>    (par_relax_interface.c:110)
>>    ==2605==    by 0x8AFC310: hypre_BoomerAMGCycle (par_cycle.c:386)
>>    ==2605==    by 0x8AEE09E: hypre_BoomerAMGSolve (par_amg_solve.c:
>> 252)
>>    ==2605==    by 0x8AE4A25: HYPRE_BoomerAMGSolve
>> (HYPRE_parcsr_amg.c:76)
>>    ==2605==    by 0x855AAA4: PCApply_HYPRE (hypre.c:172)
>>    ==2605==    by 0x8606095: KSPSolve_PREONLY (preonly.c:29)
>>    ==2605==    by 0x85A85D3: KSPSolve (itfunc.c:385)
>> 93,488
>>    alloc'd
>> (csr_matrix.c:91)
>> (mhyp.c:174)
>>    ==2605==
>>    ==2605==    at 0x8B1ADC0: hypre_BoomerAMGRelax (par_relax.c:196)
>> 252)
>>    ==2605==  Address 0xcded820 is 0 bytes after a block of size
>> 93,488
>>    alloc'd
>> (csr_matrix.c:91)
>> (mhyp.c:174)
>>    ==2605==
>>        Try valgrind.
>>         Matt
>>        On Sat, Nov 14, 2009 at 3:32 PM, Dominik Szczerba
>>        <dominik at itis.ethz.ch <mailto:dominik at itis.ethz.ch>
>>        <mailto:dominik at itis.ethz.ch <mailto:dominik at itis.ethz.ch>>>
>> wrote:
>>           Now for something more serious: I get a crash like this
>> one:
>>           Starting KSPSolve (1/2)
>>            0 KSP Residual norm 2.964538623545e-06
>>           *** glibc detected *** /home/domel/build/solve-debug/
>> ns3t10mpi:
>>           malloc(): memory corruption: 0x09258008 ***
>>           ======= Backtrace: =========
>>           /lib/tls/i686/cmov/libc.so.6[0x5f9ff1]
>>           /lib/tls/i686/cmov/libc.so.6[0x5fcbb3]
>>           /lib/tls/i686/cmov/libc.so.6(__libc_calloc+0xa9)[0x5fe009]
>> ns3t10mpi(hypre_CAlloc+0x2c)[0x8b4ea28]
>> ns3t10mpi(hypre_BoomerAMGCoarsenRuge+0xb5)[0x8af2c7b]
>>           (and so on)
>>           gdb invoked as:
>>           mpiexec -np 2 ..... -on_error_attach_debugger -display :0.0
>>           does not display any backtrace after the crash.
>>           Any hints how to debug are highly appreciated.
>>           Dominik
>>        --         What most experimenters take for granted before
>> they begin their
>>        experiments is infinitely more interesting than any results to
>>        which their experiments lead.
>>        -- Norbert Wiener
>> -- Norbert Wiener
