Reuse matrix and vector
jarunan at ascomp.ch jarunan at ascomp.ch
Tue Nov 10 06:02:12 CST 2009
Quoting Jed Brown <jed at 59A2.org>:
> jarunan at ascomp.ch wrote:
>> Total number of cells is 744872, divided into 40 blocks. In one
>> processor, MatCreateMPIAIJWithArrays() takes 0.097 sec but 280 sec with
>> 4 processors. Usually, this routine has no problem with small test case.
>> It works the same for one or more than one processors.
> This sounds like incorrect preallocation.  Is your PETSc built with
> debugging?  Debug does some extra integrity checks that don't add
> significantly to the time (although other Debug checks do), but it would
> be useful to know that they pass.  In particular, it checks that your
> rows are sorted.  If they are not sorted then PETSc's preallocation
> would be wrong.  (I actually don't think this requirement enables
> significantly faster implementation, so I'm tempted to change it to work
> correctly with unsorted rows.)
The code is compiled with the optimized version of PETSc. The row
indices and column indices for each row are sorted. Well, they are not
sorted for diagonal or off-diagonal part.
> You can also run with -info |grep malloc, there should be no mallocs in
> MatSetValues().
Here are the output.
The first serie of MatAssemblyEnd_SeqAIJ() should be in
MatCreateMPIAIJWithArrays(), which mallocs in MatSetValues() are not
zero.
Would MatCreateMPIAIJWithSplitArrays() be better in preallocation?
[0] VecAssemblyBegin_MPI(): Stash has 0 entries, uses 0 mallocs.
[0] VecAssemblyBegin_MPI(): Block-Stash has 0 entries, uses 0 mallocs.
[2] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[1] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[3] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[0] MatAssemblyBegin_MPIAIJ(): Stash has 0 entries, uses 0 mallocs.
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 4379
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 13859
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 20286
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 4592
[3] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 15042
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 11715
[0] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[2] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[1] MatAssemblyEnd_SeqAIJ(): Number of mallocs during MatSetValues() is 0
[0] MatIncreaseOverlap_MPIAIJ_Receive(): Allocated 0 bytes, required 3
bytes, no of mallocs = 0
