Can I use MatSetBlockSize() for MPIAIJ
Ryan Yan vyan2000 at gmail.com
Sat Nov 7 14:17:01 CST 2009
Hi Jed,
So the following is very confusing:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetValuesBlocked.html
Notes The m and n count the NUMBER of blocks in the row direction and column
direction, NOT the total number of rows/columns; for example, if the block
size<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/size.html#size>is
2 and you are passing in values for rows 2,3,4,5 then m would be 2
(not
4). The values in idxm would be 1 2; that is the first index for each block
divided by the block
size<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Sys/size.html#size>.
Note that you must call
MatSetBlockSize<http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatSetBlockSize.html#MatSetBlockSize>()
when constructing this matrix (and before preallocating it).........
On Sat, Nov 7, 2009 at 3:12 PM, Jed Brown <jed at 59a2.org> wrote:
> Ryan Yan wrote:
> > Hi All,
> > I have a question as follows:
> > In order to use MatSetValuesBlocked() for a MPIAIJ matrix. I need to
> > call MatSetBlockSize() when I create the matrix.
> Call MatSetBlockSize *after* preallocation.
> Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091107/d160b583/attachment.htm>
