Can I use MatSetBlockSize() for MPIAIJ
Ryan Yan vyan2000 at gmail.com
Sat Nov 7 14:01:46 CST 2009
Sorry a typo:
  MatCreate(MPI_COMM_WORLD,*A);
On Sat, Nov 7, 2009 at 2:57 PM, Ryan Yan <vyan2000 at gmail.com> wrote:
> Hi All,
> I have a question as follows:
> In order to use MatSetValuesBlocked() for a MPIAIJ matrix. I need to call
> MatSetBlockSize() when I create the matrix.
> so I did the following. Here the blocksize = 5;
> Mat *A;
>   MatCreate(MPI_COMM_WORLD,A);
>   MatSetSizes(*A,m*blocksize,n*blocksize,M*blocksize,N*blocksize);
>   MatSetType(*A,MATMPIAIJ);
>   MatSetBlockSize(*A,blocksize);
>   ierr=MatMPIAIJSetPreallocation(*A,0,ourlens_ptws,0,offlens_ptws);
> CHKERRQ(ierr);
>   ierr = MatAssemblyBegin(*A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>   ierr = MatAssemblyEnd(*A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>   PetscPrintf(PETSC_COMM_WORLD,"the bs BEFORE is %d\n", bs);
>   MatGetBlockSize(*A,&bs);
>   PetscPrintf(PETSC_COMM_WORLD,"the bs is %d\n", bs);
>   PetscPrintf(PETSC_COMM_WORLD,"the blocksize is %d\n", blocksize);
> The output I get is:
> the bs BEFORE is 0
> the bs is 1
> the blocksize is 5
> It seems like the Mat A does not absorb the information blocksize=5 at all.
> How should I make the function-call sequence correct, if I want to set a
> blocksize for the MPIAIJ.
> Thanks for any suggestions in advance,
> Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20091107/09c9ca24/attachment.htm>
