set a column of a matrix
Umut Tabak u.tabak at tudelft.nl
Sun Nov 1 10:57:23 CST 2009
On Sun, Nov 01, 2009 at 07:44:58AM -0600, Barry Smith wrote:
>    MatSetValues() so long as you have good matrix preallocation this
> will work fine.
>    Doing a transpose is very expensive.
Dear Barry and Matt,
     Thanks for the replies, I am not doing anything in parallel. I
     should use MatSetValues with appropriate column and row indices.
     Actually, what I would like to do, I would like to set up a
     vectorset(rectangular) and assign to a block in a matrix. Is
     there a vectorset that I could use directly to somehow put
     these vectors directly into this set. And use this vectorset to
     set some part of a matrix.
     Thanks for the advice in advance.
     BR,
     Umut
Quote:    	Coming together is a beginning, staying together is progress, and working together is success.
Author:   	Henry Ford 1863-1947, American Industrialist, Founder of Ford Motor Company
