MatLUFactor for Complex Matrices - Returns inverse of the diagonal in LU??
Wed May 27 20:09:48 CDT 2009
On May 27, 2009, at 8:06 PM, Paul Dostert wrote:
> Barry,
> Thank you so much for getting back to me so quickly. Just out of
> curiosity, is there a slightly more in depth version of the
> documentation that I would be able to look at if I have some other
> "simple" questions like this in the future?
    No, all the docs that exist are included with the software. The
details are in the source code. For the basic AIJ matrices the source
code is src/mat/impls/aij/seq
    Barry
> On Wed, May 27, 2009 at 5:59 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
>   Paul,
>     In PETSc for the AIJ sparse matrix storage format we store the
> inverse of the diagonal entries of U. This is because then when it
> comes to the triangular solves they only involve floating point
> multiplies and adds (no time consuming divisions). I think this is
> pretty common for sparse matrix solvers. You could argue that the
> MatView() should invert those values so what gets printed out is
> clearer; I view the MatView() for factored matrices as only a useful
> tool for debugging for developers so it just prints out the stored
> values. Yes it is a bit confusing.
>    Barry
>   For BAIJ matrices it gets even more confusing. With BAIJ the
> factorizations use the little blocks of the matrix as the basic
> computational unit of the factorization. Here we actually compute
> the exact inverse of the diagonal block and store that (a block
> version of what we do for AIJ). Again this is to make the solves as
> efficient as possible.
> On May 27, 2009, at 6:20 PM, Paul Dostert wrote:
> I'm a beginner with PETSc, so please forgive me if this is obvious,
> but I
> couldn't seem to find any help in the archives.
> I'm trying to just the hang of the software, so I've been messing
> around
> with routines. I'm going to need complex matrices (Maxwell's with
> PML) so
> everything is configured for this. I'm messing around with some very
> simple
> test cases, and have a symmetric (but not Hermitian) complex matrix
> with
> 2-2i on the diagonal and -1+i on the upper and lower diagonals. I am
> reading
> this in from a petsc binary file (again, for testing purposes,
> eventually
> I'm going to be just reading in my matrix and RHS). I view the
> matrix, and
> it has been read in correctly. I perform LU factorization by doing the
> following (where ISCreateStride(PETSC_COMM_WORLD,m,0,1,&perm); has
> been
> called earlier):
> MatConvert(A,MATSAME,MAT_INITIAL_MATRIX,&LU);
> MatFactorInfoInitialize(&luinfo);
> MatLUFactor(LU,perm,perm,&luinfo);
> I get that LU is:
>  (1,1)      0.2500 + 0.2500i
>  (2,1)     -0.5000
>  (1,2)     -1.0000 + 1.0000i
>  (2,2)      0.3333 + 0.3333i
>  (3,2)     -0.6667
>  (2,3)     -1.0000 + 1.0000i
>  (3,3)      0.3750 + 0.3750i
>  (4,3)     -0.7500
>  (3,4)     -1.0000 + 1.0000i
>  (4,4)      0.4000 + 0.4000i
>  (5,4)     -0.8000
>  (4,5)     -1.0000 + 1.0000i
>  (5,5)      0.4167 + 0.4167i
>  (6,5)     -0.8333
>  (5,6)     -1.0000 + 1.0000i
>  (6,6)      0.4286 + 0.4286i
> Now, I am interpreting this as L being unit on the diagonal and the
> lower diagonal portion of this "LU" matrix, while U being the diagona
> + upper of this "LU" matrix. I can interpret this the other way around
> as well, and it doesn't matter.
> However, knowing the LU factorization, it is VERY clear the the proper
> LU decomposition would have the inverse of the diagonal elements
> presented here. So I believe I should have  LU as:
>  (1,1)      2.0000 - 2.0000i
>  (2,1)     -0.5000
>  (2,2)      1.5000 - 1.5000i
>  (3,2)     -0.6667
>  (3,3)      1.3333 - 1.3333i
>  (4,3)     -0.7500
>  (4,4)      1.2500 - 1.2500i
>  (5,4)     -0.8000
>  (5,5)      1.2000 - 1.2000i
>  (6,5)     -0.8333
>  (6,6)      1.1667 - 1.1667i
> Is there some reason this returns the inverse of the diagonal entries,
> or am I completely missing something? Is returning the inverse
> something standard??
> Since I'm new, I'm not quite sure where to look for actual source
> code. Is there a location where the LU factorization code is written
> and well commented?
> Thank you very much!
