include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 17:37:52 CDT 2009
It seems the line
include ${PETSC_DIR}/conf/base
is not taken into account the make command
on my Mac OS.
Is it ony a gnu make directive please ?
Tahar
Le 16 mai 09 à 00:29, Satish Balay a écrit :
> On Fri, 15 May 2009, Satish Balay wrote:
>> Verify if PETSc examples work [both C and fortran] - and if so - use
>> PETSc makefiles..
>> Attaching one in the simplest form [after removing the unnecessary
>> stuff from - src/ksp/ksp/examples/tutorials/makefile]
> You are using PETSc from fortran - so use the attached makefile
> and replace ex1f[.F] with the name of your source file[s].
> Satish<makefile.txt>
