include file fortran
Tahar Amari amari at cpht.polytechnique.fr
Fri May 15 17:26:37 CDT 2009
By the way I forgot to say that ,
I build mpich with C++ and fortran and both works. So I assumed that
petsc would work too.
Tahar
Le 16 mai 09 à 00:21, Satish Balay a écrit :
> If using PETSc from fortran - why use --with-clanguage=cxx ?
> Also - verify if PETSc examples work - before attempting your code.
> And then use PETSc makefiles.
> [i.e copy the makefile from PETSc example dir - and modify the target
> to build your code]
> Satish
> On Sat, 16 May 2009, Tahar Amari wrote:
>> Just to let you know is that I built petsc with c++ anyway since I
>> did
>> configure -with-cc=gcc --download-mpich=1 --download-parmetis=1
>> --with-#shared=0 --download-f-blas-lapack --with-clanguage=cxx --
>> with-cxx=g++
>> --with-fc=ifort --with-dynamic=0
>> Tahar
>> Le 15 mai 09 à 23:49, Matthew Knepley a écrit :
>>> On Fri, May 15, 2009 at 4:35 PM, Tahar Amari <amari at cpht.polytechnique.fr
>>> wrote:
>>> Thanks ,
>>> Now this a different kind of errors (just a piece of those below :)
>>> If you want to use C++, you should configure using --with-
>>> clanguage=cxx.
>>> Then you will get the C++ linker.
>>> Matt
>>> gcc  -o  mh4d mh4d.o petsc.o comm.o setbc.o local.o gridutil.o
>>> mympi.o
>>> terminator.o operator.o shellsort.o edge.o side.o vertex.o
>>> tetrahedron.o
>>> rotation.o tetrahedralgrid.o field.o   -I/usr/local/hdf/HDF4.2r1/
>>> include
>>> -L/usr/local/hdf/HDF4.2r1/lib -lmfhdf -ldf -lsz -ljpeg -lz
>>> -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -
>>> lpetsccontrib
>>> -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lmpichcxx -lpmpich
>>> -lfmpich
>>> -lmpichf90 -lparmetis -lmetis -lfblas -lflapack  -L/usr/X11R6/lib -
>>> lX11 -lXt
>>> -lXext -lX11  -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -
>>> lpetscmat
>>> -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -
>>> lmpichcxx
>>> -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
>>> Undefined symbols:
>>> "std::basic_ostringstream<char, std::char_traits<char>,
>>> std::allocator<char>
>>>> ::basic_ostringstream(std::_Ios_Openmode)", referenced from:
>>>    PetscErrorCxx(int, char const*, char const*, char const*, int,
>>> int)in
>>> libpetsc.a(err.o)
>>>    PETSc::Exception::Exception(std::basic_string<char,
>>> std::char_traits<char>, std::allocator<char> > const&)in
>>> libpetsc.a(err.o)
>>> "_for_stop_core", referenced from:
>>>    _advmom_cv_ in mh4d.o
>>>    _terminators_mp_terminator_ in terminator.o
>>>    _terminators_mp_terminator_all_ in terminator.o
>>>    _tetrahedralgrid_mod_mp_zero_bndr_tvv_ in tetrahedralgrid.o
>>> Le 15 mai 09 à 23:29, Matthew Knepley a écrit :
>>> CLINKER
>>> What most experimenters take for granted before they begin their
>>> experiments
>>> is infinitely more interesting than any results to which their
>>> experiments
>>> lead.
>>> -- Norbert Wiener
