include file fortran
Fri May 15 17:15:02 CDT 2009
On Fri, May 15, 2009 at 5:10 PM, Tahar Amari <amari at cpht.polytechnique.fr>wrote:
> I changed CLINKER to g++ and the symbols where found.
This does not make sense. What version are you using? The latest?
> Now I have other remaining errors  which seams to be link with some petsc
> fortran ?
> Do you have any idea please where (which petsc library) those symbols are
> supposed to be in ?
Those symbols are not in PETSc. They look like Fortran symbols, and so
should be included in
PETSC_TS_LIB, if you configured with the same Fortran compiler that you used
to compile
those files.
If you want to talk about it more, more the discussion to
petsc-maint at mcs.anl.gov and send the
configure.log.
  Matt
> Many thanks
> Tahar
> Undefined symbols:
>   "_for_stop_core", referenced from:
>       _advmom_cv_ in mh4d.o
>       _terminators_mp_terminator_ in terminator.o
>       _terminators_mp_terminator_all_ in terminator.o
>       _tetrahedralgrid_mod_mp_zero_bndr_tvv_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_idnt_bndr_tvv_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_v2v_operator_bc_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_tvvaxpy_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_v2v_scalar_bc_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_zero_bndr_tvs_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_v2v_operator_bc0_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_v2v_operator_bct_ in tetrahedralgrid.o
>       _xerbla_ in libfblas.a(xerbla.o)
>   "_for_exit", referenced from:
>       _tetrahedralgrid_mod_mp_partition_tetragrid_ in tetrahedralgrid.o
>   "_for_write_seq", referenced from:
>       _wrrsfile_ in mh4d.o
>       _tetrahedralgrid_mod_mp_save_tcs_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_save_tvs_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_save_tcv_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_save_tvv_ in tetrahedralgrid.o
>       _tetrahedralgrid_mod_mp_write_tetragrid_data_ in tetrahedralgrid.o
>   "_for_check_mult_overflow", referenced from:
> Le 16 mai 09 à 00:00, Matthew Knepley a écrit :
> On Fri, May 15, 2009 at 4:56 PM, Tahar Amari <amari at cpht.polytechnique.fr>wrote:
>> I am sorry (I might have missed something)
>>  If you want to use C++, you should configure using --with-clanguage=cxx.
>>> Then you will get the C++ linker.
>> I do not really want to use C++ linker
>> I did it with the C Linker and got an error. I do not see where the C++ is
>> now used
> You have C++ code in there somewhere. It is hard to see what is going on
> since we do not have the source.
>   Matt
>> Tahar
>> cc  -o  mh4d mh4d.o petsc.o comm.o setbc.o local.o gridutil.o mympi.o
>> terminator.o operator.o shellsort.o edge.o side.o vertex.o tetrahedron.o
>> rotation.o tetrahedralgrid.o field.o   -I/usr/local/hdf/HDF4.2r1/include
>> -L/usr/local/hdf/HDF4.2r1/lib -lmfhdf -ldf -lsz -ljpeg -lz
>> -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat -lpetsccontrib
>> -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lmpichcxx -lpmpich -lfmpich
>> -lmpichf90 -lparmetis -lmetis -lfblas -lflapack  -L/usr/X11R6/lib -lX11 -lXt
>> -lXext -lX11  -L/usr/local/petsc/macx/lib -lpetscsnes -lpetscvec -lpetscmat
>> -lpetsccontrib -lpetscts -lpetscdm -lpetscksp -lpetsc -lmpich -lmpichcxx
>> -lpmpich -lfmpich -lmpichf90 -lparmetis -lmetis -lfblas -lflapack
>> Undefined symbols:
>>  "std::basic_ostringstream<char, std::char_traits<char>,
>> std::allocator<char> >::basic_ostringstream(std::_Ios_Openmode)", referenced
>> from:
>>      PetscErrorCxx(int, char const*, char const*, char const*, int, int)in
>> libpetsc.a(err.o)
>>      PETSc::Exception::Exception(std::basic_string<char,
>> std::char_traits<char>, std::allocator<char> > const&)in libpetsc.a(err.o)
> experiments lead.
> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090515/abf2fe1a/attachment.htm>
