MatLoad a large matrix into SEQAIJ
SUN Chun Chun.SUN at 3ds.com
Fri May 15 14:08:04 CDT 2009
Thank you so much for the help. I'll first try upgrading and making sure to separate the issue before uploading.
Chun
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov [mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
Sent: Friday, May 15, 2009 2:02 PM
To: PETSc users list
Subject: Re: MatLoad a large matrix into SEQAIJ
If you still have issues - you an upload the matrix to
ftp://ftp.mcs.anl.gov/pub/incoming and then we can take a look.
Satish
On Fri, 15 May 2009, Matthew Knepley wrote:
> I have not seen this. I would recommend upgrading.
>   Matt
> On Fri, May 15, 2009 at 8:58 AM, SUN Chun <Chun.SUN at 3ds.com> wrote:
> >     Hello PETSc developers,
> > I was trying to MatLoad a large matrix into a serial machine. The matrix is
> > about 6G on disk (binary). I'm seeing signal 11 on MatLoad phase. However, I
> > was able to load other smaller matrices (less than 1G) in serial (although I
> > haven't binary-searched to find out what is the critical size of the crash).
> > Also, I was able to load the 6G matrix when I ran with 4 cores, meaning
> > SEQAIJ type has become  MPIAIJ type. BTW I built and ran PETSc on both
> > 64-bit lnx86_64 machines.
> > I'm not sure if you have seen this. I'm not sure if this is a bug because
> > I'm still using 2.3.3 instead of 3.0, and I also suspect I might have missed
> > something on build or run. Have you seen this?
> > Thanks,
> > Chun
