MatLoad a large matrix into SEQAIJ
SUN Chun Chun.SUN at 3ds.com
Fri May 15 08:58:02 CDT 2009
Hello PETSc developers,
I was trying to MatLoad a large matrix into a serial machine. The matrix is about 6G on disk (binary). I'm seeing signal 11 on MatLoad phase. However, I was able to load other smaller matrices (less than 1G) in serial (although I haven't binary-searched to find out what is the critical size of the crash). Also, I was able to load the 6G matrix when I ran with 4 cores, meaning SEQAIJ type has become  MPIAIJ type. BTW I built and ran PETSc on both 64-bit lnx86_64 machines.
I'm not sure if you have seen this. I'm not sure if this is a bug because I'm still using 2.3.3 instead of 3.0, and I also suspect I might have missed something on build or run. Have you seen this?
Chun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20090515/787ef123/attachment-0001.htm>
