Conjugate Gradient technique
Barai, Pallab baraip at ornl.gov
Thu May 14 16:36:43 CDT 2009
Thank you very much Barry for the solution. I will give it a try.
Pallab
-----Original Message-----
From: petsc-users-bounces at mcs.anl.gov on behalf of Barry Smith
Sent: Thu 5/14/2009 5:29 PM
To: PETSc users list
Subject: Re: Conjugate Gradient technique
   You just pass the shell matrix into KSPSetOperators() and
KSPSolve() will do the rest.
   Note: you will need to use -pc_type none as the preconditioner
since you are not providing a matrix from which to build the
preconditioner.
    Barry
On May 14, 2009, at 4:26 PM, Barai, Pallab wrote:
> Hello Matt,
> Thank you very much for your reply.
> Here "S" is a symmetric matrix, so I have to use the CG.
> But I can not figure out how to use the Conjugate Gradient technique
> to find the solution. In the "MatShell" I can wrap my "MatVec"
> routine which calculates the "S*x" vector.
> But how will I be able to do the comparison between the known "b"
> vector and the calculated "S*x" using a CG (and come up with a new
> trial solution "x" for the next iteration). What is the function
> that I should call for this purpose?
> Thanking you.
> Pallab
> From: petsc-users-bounces at mcs.anl.gov on behalf of Matthew Knepley
> Sent: Thu 5/14/2009 5:03 PM
> On Thu, May 14, 2009 at 3:58 PM, Barai, Pallab <baraip at ornl.gov>
> wrote:
>> Hello,
>> I am using PETSc to solve a set of linear equations "Sx=b".
>> Here "b" is known and "x" is the trial solution.
>> The complete (assembled) form of S is not known. That is why I am
>> not able
>> to use something like "KSPSolve".
>> But given a trial solution "x", I can calculate "S*x" using a
>> "MatVec"
>> routine.
>> Is it possible to use the Conjugate Gradient (CG) technique to find a
>> solution in this case? In place of "S", I can give "S*x" as the
>> input.
> You can use CG if S is symmetric. If not, try GMRES.
>> It will be great if someone can show me some direction. If this
>> thing has
>> already been discussed before, the link to that thread will be
>> sufficient.
> You can wrap your function in a MatShell:
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manualpages/Mat/MatCreateShell.html
>   Matt
>> Thanking you.
>> Pallab Barai
> experiments
> is infinitely more interesting than any results to which their
> experiments
> lead.
> -- Norbert Wiener
