user's own preconditioner for PCG
Thu May 7 16:11:44 CDT 2009
   See the manual page for PCSHELL
On May 7, 2009, at 4:09 PM, Shao-Ching Huang wrote:
> Hi,
> In a parallel PCG solve, is there a way to instruct PETSc to call my
> own (serial) solver to invert the per-process, local precondition
> matrix (as in the block-Jacobi preconditioner)?
> Is there an example/documentation that I can follow? Which part of
> code should I start looking at?
> We are trying to determine if there is any value to use the
> aforementioned customized preconditioner as compared to the general
> ones in PETSc and to DMMG, for this particular matrix at hand. This
> is a structured mesh problem.
> Thank you.
> Shao-Ching
